On this new network I’ve seen the first costs that aren’t the minimum:-
1728699826,0.000000005,1728699835,5927019931135107
1728729511,0.000000004,1728729521,4565542461189369
1728740307,0.000000004,1728740320,1448817460363965
Before the collapse some of my nodes were quoting 3 nanos
Costs seem to be back to much normal levels. Here are the last 10 quotes for example:-
tail -f ~/safe_cost_tracker/logs/safe_cost_tracker.log
1728810280,0.000000006,1728810301,8315150222405726
1728810361,0.000000076,1728810373,9132303242002534
1728810433,0.000000004,1728810463,7779084535258123
1728810523,0.000000010,1728810537,2090645817409653
1728810597,0.000000005,1728810620,8217248688079688
1728810680,0.000000004,1728810705,7542234538634010
1728810765,0.000000007,1728810785,1333205392617133
1728810845,0.000000005,1728810855,1827948780155106
1728810915,0.000000012,1728810927,5196225431363849
1728810987,0.000000003,1728811009,6432880165180578
But there were some high ones earlier. Here are the top 10:-
./scripts/costs_not_3_nanos | sort -t , -k 2 | tail
1728794187,0.000001243,1728794212,5618947665888386
1728805855,0.000001537,1728805892,1426117348175723
1728802409,0.000001735,1728802428,3195914047212750
1728784409,0.000001949,1728784437,2279542541739856
1728781717,0.000002056,1728781744,1277870300133976
1728800022,0.000002106,1728800050,7451561226930315
1728788250,0.000002221,1728788284,3570231062109980
1728798699,0.000002416,1728798729,1549471170671762
1728806522,0.000003041,1728806547,2166141451210611
1728806607,0.000003901,1728806623,9495960920297580
BUT! note that we don’t have the crazy ones in the millions of nanos or whole numbers of tokens we’ve seen when other networks have gone south.
We’re back at 50k 10k nodes =)
Bah! The ‘estimate’ option isn’t there anymore!
Is it coming back?!
autonomi file estimate tempcost
error: unrecognized subcommand 'estimate'
Usage: autonomi file [OPTIONS] <COMMAND>
For more information, try '--help'.
autonomi -h
Autonomi CLI
Usage: autonomi [OPTIONS] <COMMAND>
Commands:
file Operations related to file handling
register Operations related to register management
vault Operations related to vault management
help Print this message or the help of the given subcommand(s)
Options:
--log-output-dest <LOG_OUTPUT_DEST> Specify the logging output destination. [default: data-dir]
--log-format <LOG_FORMAT> Specify the logging format.
--first Set to indicate this is the first node in a new network
--peer <multiaddr> Peer(s) to use for bootstrap, in a 'multiaddr' format containing the peer ID [env:
SAFE_PEERS=]
--network-contacts-url <NETWORK_CONTACTS_URL> Specify the URL to fetch the network contacts from
--timeout <CONNECTION_TIMEOUT> The maximum duration to wait for a connection to the network before timing out
-x, --no-verify Prevent verification of data storage on the network
-h, --help Print help (see more with '--help')
-V, --version Print version
its called cost now
$autonomi file cost -h
Estimate cost to upload a file
Usage: autonomi file cost [OPTIONS] <FILE>
Arguments:
<FILE> The file to estimate cost for
Options:
timing out
-x, --no-verify
-h, --help
Thank you for that @aatonnomicc .
I love the fact that a balance is no longer required to find the cost of an upload! I had been worried what I was going to do about that with the shift to a new token.
It’s ancient history now but what I had been doing before was just updating ‘safe’ with ‘safeup client’ for each network using a wallet that had the minimal amount in it from earlier in the year. It seems the client just checked that there was a balance and not that it was a balance that would work on the current network. So I got away with not having to transfer a real nano to it.
I have one more question: is there still a chunk_artifacts
directory? I can’t find one. I ask because my script removes the contents after each run or it will eventually fill the disk. It used to be at:-
$HOME/.local/share/safe/client/chunk_artifacts
but I can’t find an equivalent under:-
$HOME/.local/share/safe/autonomi
same here iv checked around and don’t see anything in the obvious places and im trying to upload stuff right now.
I was worried they were going into /tmp
again. I still think they must be going somewhere. Unless they are being deleted right after they are finished with.
Maybe they aren’t anywhere! Didn’t find anything with find / -name "chunk" 2>/dev/null
Maybe I’ll find out in a couple of days if the disk fills and stops the machine!
Are you sure they haven’t changed the process to delete the artifact directory used as soon as the chunks are generated and the chunk hash and xor address has been determined?
I am not sure about that at all. And that is what I am beginning to think!
I’m tracking the costs over time on the new network in case there are any oddities but the cost is still being quoted in nanos and is therefore wrong! eg.
0.000000008
when it should be
0.000000000000000008
Maybe I’ll fudge the entries so far later when this is corrected.
It would be really good if the autonomi client could be amended so the upload cost makes sense.
It must be working right behind the scenes as not even @aatonnomicc will have earned enough to upload files yet!
I realise it is low priority while there aren’t ‘real’ users using earnings or bought tokens paying to upload at the moment.
I’m not seeing any costs that are any different than 8 attos. But I’ve now seen 7 failures to get a quote. I’m logging the times though and this is when the failures occurred:-
Fri Nov 1 01:37:22 UTC 2024
Fri Nov 1 19:17:48 UTC 2024
Fri Nov 1 20:57:32 UTC 2024
Sat Nov 2 01:58:59 UTC 2024
Sat Nov 2 06:19:54 UTC 2024
Sat Nov 2 08:06:28 UTC 2024
Sat Nov 2 08:22:10 UTC 2024
Sat Nov 2 09:05:07 UTC 2024
I’m also logging the data used to create the file to get the cost so I tried to get quotes for the files that couldn’t get quotes the first time and found something worrying: one of them persistently can’t get a quote:-
1730425042,,1730425063,9233318131286619 = no after 10 tries
1730488668,,1730488704,8095503472183410 = yes after 1 try
1730494652,,1730494705,2461373484827844 = yes after 1 try
1730512739,,1730512775,6523631753218929 = yes after 1 try
1730528394,,1730528434,8299917177419278 = yes after 1 try
1730534788,,1730534818,1298673401730602 = yes after 1 try
1730535730,,1730535751,5745222656530661 = yes after 1 try
1730538307,,1730538346,7044208582765352 = yes after 2 tries
Steps to reproduce:-
echo 9233318131286619 > tempfile
time autonomi file cost tempfile
Logging to directory: "/home/ubuntu/.local/share/safe/autonomi/logs/log_2024-11-02_09-26-07"
autonomi client built with git version: stable / a44fd08 / 2024-10-29
🔗 Connected to the Network Getting upload cost...
Error:
0: Failed to calculate cost for file
1: Cost error: Could not get store quote for: ad4037(10101101).. after several retries
2: Could not get store quote for: ad4037(10101101).. after several retries
autonomi-cli/src/commands/file.rs:26
real 0m5.167s
user 0m0.541s
sys 0m0.201s
Are there ‘holes’ in the network where data in certain ranges can’t be quoted for and stored?!
iv noticed that some files just will not upload no matter how many times i try to upload when other files of similar size upload on the 1st attempt.
I wonder if there are nodes not able to receive unsolicited packets? IE bad port forwarding or firewall.
This would result in the network leading the client to request quotes from those nodes but the nodes never see the request due to firewall blockage or port forwarding not setup right.
The nodes talk to the other nodes because they setup the comms through the router/firewall and returning packets are let through as expected. This would also include later unsolicited packets from those nodes previously contacted.
If enough nodes are like that out there then one would expect there is a high chance in such a small network that there are some chunks which will have 5 such nodes as the closest nodes.
That points to failures depending on which nodes a chunk lands on.
I’ve noticed some very odd behaviour on the other side. Nodes earning at vastly different rates. Can’t see the pattern yet, but it seems that starting a small number can out earn an established slightly larger number on a more powerful VPS. I didn’t see this in any earlier tests so I think the changes to around shunning might be causing problems. I’m running enough to ensure none kill themselves due to CPU so it isn’t that.
Seeing some costs that are more than 8 attos for the first time on this network.
./scripts/costs_top_20
1730928112,0.000000011,1730928152,4777004043057656
1730933533,0.000000011,1730933567,1577111990547591
1730933067,0.000000013,1730933100,4262788603772566
1730934007,0.000000016,1730934035,7353417455416006
1730936092,0.000000016,1730936127,3747605298812151
1730938335,0.000000018,1730938366,5491007809536739
1730937961,0.000000020,1730937995,6079789096723514
1730934280,0.000000021,1730934311,2125213942795747
1730937473,0.000000021,1730937506,6937989752850428
1730936559,0.000000022,1730936604,1747779627085995
1730925924,0.000000023,1730925968,4376035357549416
1730934465,0.000000025,1730934494,3565956987375427
1730932576,0.000000032,1730932618,7344387638403538
1730926209,0.000000034,1730926242,4679319513283855
1730934190,0.000000034,1730934220,3981085368493576
1730935250,0.000000035,1730935281,2638391719970966
1730933914,0.000000036,1730933947,3262441009698343
1730938152,0.000000038,1730938189,4476639712801320
1730931968,0.000000039,1730931997,9301596087100037
1730932261,0.000000039,1730932314,8480666873332371
Along with still seeing some files that can’t be quoted for at all.
Each of my nodes claim there are like 20 to 50 bad nodes out there. So I guess its expected there could be some cases, the network is not in the best of conditions at the moment
I started 5 nodes yesterday and one quoted 33 and had 2k records.
None have earned anything though
I’m seeing lots of failures to quote again.
