I’ve been going through the RFC on node ageing, and any forum post I can find to try and understand how this magic (node ageing) protects the network. I’m so far not convinced this adds ‘definable’ security.
To summaries my findings, ‘behave correctly or we will disconnect your node, and you might get half your age back on reconnecting’. The restoring age by ‘Using the group members to request any data the node has to verify age’, seems inefficient, and if am an attacker with some big nodes (and I no longer care about my age), I could just keep restarting them to drain my groups resources.
A ‘normal’ person is going to find it difficult to keep a node online without disconnects, and with the maximum node age taking up to 60000 years. Will an attacker get an advantage from setting up infratructure / custom distributed vaults to appear always online to get a really high node age? if I get to node age 5 years of churn, my single node would make up 50% of the group age, no matter which group I am in.
Can someone please explain to me why, the network is not using its fundermental properties to protect its purpose. The data itself, which to me, seems a much more direct and powerful / simple way of achieving the result of ‘node ageing’
- Data is evenly distirbuted. So influence is distributed.
- Chucks being requested often, are copy. So more influence is created and distributed.
- Nodes that are overloaded / high latency. Will fail to / be accused of not providing data requested. Network can reduce influence, while restoring a node to a health state of not being overloaded
Protection:
- Restarting loads of empty nodes, will have zero effect on the network
- Running multiple nodes from the same IP not a problem (IPv6 makes using unique IPs pointless)
- Influence is not lost by disconnects (Can the other nodes holding copies of the data, form a computational challenge for the node to prove it still has its data?)
- Groups are an average of the currently distributed influence, so no single node becomes super powerful.
- 51% attack means, you hold 51% of the data in the group, which no single node will have, as the data would be relocated. If you are a massive farm with many nodes and 51% of the data, which means you’ll also have all the copies of the highly requested data, you somehow have an incredible amount of bandwith too. Which should be ‘impossible’
The only problem I can think of is if I want to host an archive node (No highly active chucks stored here). The influence of the data store here will need a handicap, to reduce the influence. Which as the network ages, the handicap increases to reduce influence.
