Shu
February 12, 2025, 6:07am
21
There a few types off NATs that can be at play: full cone nat, symmetric nat, restricted cone nat, and port restricted cone nat etc.
Depending on the NAT on the VPS side, your ports that you set for your local LAN may not be the same ports seen by external peers outside of the VPS’s public IP. In other words, it may not be mapping 1:1 port mappings (internal vs external port range) regardless of your port forwarding (inbound rules).
Symmetric NAT & Variation of Restricted NAT will be further prevent connections from coming in bound back to your LAN depending on src ip/port vs dst ip/port of the request, and vice versa. In addition, it requires an initiation from your side first to outbound host, before the outbound peer can communicate back through the NAT (the rest off external hosts would get blocked).
Using the same command to add nodes:
antctl add --count 500 --node-port 49000-49499 --metrics-port 33000-33499 --rewards-address … evm-arbitrum-one
and redirecting all UDP > port 1023 to the machine, I still have antctl status
show greater than half of nodes with 0 connected peers. I’m watching firewall blocks and it’s very little.
My updated VPN’s firewall (pf) config is:
set block-policy drop
set reassemble yes
set skip on lo
nat on vtnet0 from 192.168.0.15 to any → vtnet0
no rdr on vtnet0 proto udp from any to port 6000
rdr on vtnet0 proto udp from any to port 1024:65535 → 192.168.0.15 port 1024:*
block in quick on vtnet0 to { 224.0.0.0/4, 239.0.0.0/8 }
block in quick on vtnet0 to 255.255.255.255
block in quick on vtnet0 proto udp to port 137:138
block in quick on vtnet0 from { 216.181.107/16, 216.126.234/16, 216.126.235/16 }
block log all
pass out quick on vtnet0 from any to any
pass in quick on wg0 from 192.168.0.15 to any
pass out quick on wg0 from any to 192.168.0.15
pass in quick on vtnet0 proto udp from any to any port 1024:65535
pass in quick on vtnet0 proto tcp from any to port 2200
pass in quick on vtnet0 proto udp from any to port 6000
I’ve restarted the nodes with --home-network, and now every node has (many) connected peers. How can I fix my firewall rules so that I can run with port forwarding and properly support the network?
Update: @drirmbda has hero status as adding --node-ip 192.168.0.15 fixed it (!!!) Next I’ll try tightening the firewall rules back to only forward the UDP ports I explicitly wish to forward.
neo
February 14, 2025, 12:19am
23
That could cause issues in your network, especially if you stream stuff on other machines.
If your nodes are using 49000 and above then do >= 49000
antctl is showing instantaneous active connections and not routing table peers. Routing table peers is the important figure since this shows how connected your nodes are. Look at logs or use the /metrics function and look for routing table
https://127.0.0.1:49000/metrics
Do you mean VPS? VPN might be another issue to deal with (double NAT and all that)
If VPS who is the provider and do they apply their own firewall upstream to your VPS and there is a web page to set the firewall rules for that one
So that worked for you. Does your machine have multiple NIC’s ?
Ok I was just investigating that and running some tests. What I observed was a large number of connected peers, then it’d drop down to 0. Good to know there’s a different value for a node’s routing table. IMHO it would be helpful for antctl status to show both types of peer connections for each node.
I keep getting connection refused when I try to pull from /metrics. Mind sharing a full command? Update: Nevermind, figured it out. Will answer the rest of your questions after I figure out what’s going on.
neo
February 14, 2025, 1:13am
25
And it has been said it is noted for future change when they have time
neo:
Do you mean VPS?
Both. It’s a VPS that I have configured as both a firewall and Wireguard server. I wanted something off of my home LAN so I could do better testing than I could with other node machines running and being afraid to mess all of them up.
None.
neo:
Now that I know antctl status shows a different value than routing table it’s hard to say. I must say though, --home-network seems to be performing better. (sadly)
Forward all UDP, port forwarding enabled, node ip set, starting node every 15s.
records: 0
conns:
antnode1 12D3KooWJzC9FTUueS5PwYwiVC8CWu6oJG5L5tr4vboQbA3ErHCi RUNNING 0
antnode2 12D3KooWBdwihmzb3byyLa2iFfw5QPDv2RNMzYuMEoErFHmJbqpU RUNNING 0
antnode3 12D3KooWFBigKAUwMiEnZdyefq1BkGHzFdwR9bdBjKYbNnzg8Gjp RUNNING 0
antnode4 12D3KooWALGyazkrz9KakLfTLktvGduDryrB3VjKDozz33N91TJU RUNNING 0
antnode5 12D3KooWF9y8Sd4q8E6osP82wX7JX69eqjzoD67ftjjPfTwQJ9ze RUNNING 0
antnode6 12D3KooWCZqmo8JDPs97PF2rN3Sc4HH4uH4UGHoZhpZaabrumfVN RUNNING 0
antnode7 12D3KooWFe1pikrj444MfSYH8f6cERhJbieZKLAK17x2yRsfot2t RUNNING 0
antnode8 12D3KooWRpZsGpeYQXEWumtK1hwq2XvCesH3Vt1u1gnbBgZEC21k RUNNING 0
antnode9 12D3KooWQRcDBzFmPNX6t6nFQzyD4MpWxxoFRc8v3q7AkDVcaz5B RUNNING 0
antnode10 12D3KooWDBKgWYuAFWzbEZ2zhzgR8bAj6Q2qqL6ppzcEqxaz7ZuT RUNNING 0
antnode11 12D3KooWPJNLd12GunDRXYJoP94ohKSBQ6s4S1wvXkQVDzMdZTUV RUNNING 0
antnode12 12D3KooWDZCXUUXovG2XveoXvvzXfbKAp5DETMZrvCT9UtWd1rtw RUNNING 0
antnode13 12D3KooWJB9Ju8db7cW3qRs7PfBFnSF8jFhqhjUxoM6AxqSvac8S RUNNING 0
antnode14 12D3KooWEKbKquNSqSkWCCn79vg5mS68UhQHoXCEP5pjCWXAwJBc RUNNING 7
antnode15 12D3KooWAckbU1Q4MsWkLrAJps6TBTHMKKeeifKcV8q2PBJXBeDQ RUNNING 19
antnode16 12D3KooWEoimwjEiJsZCGijfsBtjtQZ8an9CEtYYWEaL3AVoLepP RUNNING 4
antnode17 12D3KooWKVkZb7r3fyvWuBMgyySiytqj4VP927iJmmDQcSsKpqjz RUNNING 10
antnode18 12D3KooWEzGaWPwaHtSbZ7EiQmLhKYnowXKKooHgeABnhkBgRLhV RUNNING 80
antnode19 12D3KooWLqkyaxApQ8EfTZMWsiSPnHeAYDA2SETQRY88BmctSXuD RUNNING 53
antnode20 12D3KooWPERihgiFPdfv4KVPerSCUi6nCjDKCNXXzfBYhfecWXLi RUNNING 64
antnode21 12D3KooWF68o9qtqpwQZGQRZQGKGUJBXP312w1FoL7XEHUoGSQ4p RUNNING 0
antnode22 12D3KooWLmfHexiz8ZEJ2eDaQD5KKDg1Rjz3veRhvqcYGwKYZUSA RUNNING 0
antnode23 12D3KooWEYFqBB6hJwM1AX7Hj8vKoReyT9wfmA7954Zh3gLYJWEk RUNNING 0
antnode24 12D3KooWAPQq6XDYDzw7vgNZ4sH7TX4FaScRYkKVPfDb3VSDwCMG RUNNING 0
antnode25 12D3KooWQxaoezDLrGjoZCj9jiECfUkK8PhNbcuCEtuJDKgg9NYv RUNNING 0
antnode26 12D3KooWEkytm81BB3tSpRVvmNcPVvzpCf3Wh9xzR8MqSF37Cgo5 RUNNING 0
antnode27 12D3KooWSei44Vz93htPtHAYsrjTABkCpuALKWb8qSmcAeTEn8tu RUNNING 0
antnode28 12D3KooWSV7qYB3paGQ1fQmrhrFJ8CixZkWub81jhwr4G52nWNB9 RUNNING 0
antnode29 12D3KooWAcHiGbFrPnt1ESz2wBgHKPCjJ1hWj2rRSZESY54BbVsS RUNNING 0
antnode30 12D3KooWN9FURG2B4yUaYXh7iiLGF34Qe4eGWRjgoKE6kDDyPdHe RUNNING 0
antnode31 12D3KooWGqZfkVrCKqEwUfhoh6nxjWQn78dxPLxsDNFJHMRes4CC RUNNING 0
antnode32 12D3KooWJCSgMmEmhzMk5Bv1xQBTbWAeiCfQdsswkVgWRg6mWG3x RUNNING 0
antnode33 12D3KooWKPWy4n1B4iHJKVKwB7ykbKWJZeSXCkJvAKdrJWe4WDuU RUNNING 0
antnode34 12D3KooWH31RFGne242Y5khqpdTAdA6ptqHFQzDRwd3Jfq2XhSNW RUNNING 0
antnode35 12D3KooWEjQ8ZrZpHDF9SM4WEhQQn9TSkLuN6uLbaVKDqiXazD2g RUNNING 1
antnode36 12D3KooWMaCH1moRf2Ewq6ZwRZ5NMwFYiiUNyYkJvex9PRSrTQfN RUNNING 0
antnode37 12D3KooWPVMcg63o675zAKfakCPT19VZmPA9MTDPDUnwUy21AiaL RUNNING 0
antnode38 12D3KooWKmqKcAwoseuRaLVFtuavJTAAM1NvJeMS8854NFE9NenJ RUNNING 19
antnode39 12D3KooWBAgFSTGENoqLoBud4gRzHrsDf5nNm5R32nNhEDo9TaLc RUNNING 1
antnode40 12D3KooWLT2meD9JYrET5NZQ6Z36EzNwypTCCPSr1Y8htZ4RoLnR RUNNING 0
antnode41 12D3KooWGvKTki611ScnEwuThqNe8dfdUWjKUhCjyufpTs1n6eZh RUNNING 259
antnode42 12D3KooWRc6MhtkTmueChQfLNeh3FFT3JRzjsbT7R1gHTcd8abkZ RUNNING 74
antnode43 12D3KooWKjHHTFxVJTjCZ2EvXUNUcA7QMzyEEmTexMjRRx9Qkr5k RUNNING 132
antnode44 12D3KooWCZqmo8JDPs97PF2rN3Sc4HH4uH4UGHoZhpZaabrumfVN RUNNING 0
antnode45 12D3KooWHPBDTmmAiRufgxFmc1K379dPxbaz9sCN2cy4ZD5N9WcW RUNNING 762
antnode46 12D3KooWLvjoTVfosEoz6hDUMLe3EHmxcitc6Zw4kXSC3CLtaVWD RUNNING 952
antnode47 12D3KooWLQWaSB2DmvacoRQSMZbgXbZNMxmgEwpmEi18isRJnnc1 RUNNING 1008
antnode48 12D3KooWNJ5oWjHbCZ8VMzxaWkawKLzvrZAPc4ZnX1gvcAGWrXp4 RUNNING 921
antnode49 12D3KooWSufjcdjZ78251N9jAHkLY9bmCdjDFCPgMnehEiP4fVxo RUNNING 835
antnode50 12D3KooWEDm8jmLbAkTjh8EfwuvQkK8hzuxDHeYZ86H2R7hymmA5 RUNNING 625
Forward only UDP that’s port forwarded, port forwarding enabled, node ip set, starting node every 15s.
records: 0
conns:
antnode1 12D3KooWBsmAiW41dwvHh37FdYa5185qJTLYvzJBuUGqLBbyY8D1 RUNNING 0
antnode2 12D3KooWKwFAB3fHRk8qo1o6V3EJCXmJXWau6ac2v6qTpAx3MWez RUNNING 0
antnode3 12D3KooWJPns3oVP46gh9bQqTU769k1XmaPN2RndUUtP6CndEHft RUNNING 0
antnode4 12D3KooWAMZExVn5gqZuxC6CLF9azyXEGReTKeiQNxJg8atkQbgE RUNNING 0
antnode5 12D3KooWGiQrY3AmwioBcKq8BQ1maUuQo6wE1VoYsusALtq7K5PP RUNNING 0
antnode6 12D3KooWNRhEzpGkbK4xGDzj6Xhm82UstsXXTB9mCQU9w3NqZwu7 RUNNING 0
antnode7 12D3KooWNNA1iVdSeiFwGxq3wjFfotYAb4hQ8TvLwoXq3jE98NLe RUNNING 0
antnode8 12D3KooWPaoi2kMSeL37snXKFxhVg3aUYYr9sSLZQBpDX5WajZoR RUNNING 0
antnode9 12D3KooWEUjYM11yf8NvMpW97dwoS8E7Na3rS93QAyWwyndTqzq6 RUNNING 0
antnode10 12D3KooWNPsur9k7eFxNd1FMNsk8edydCPg9fnykpVKKDWjkVQWa RUNNING 0
antnode11 12D3KooWQAXH9naCi4wKz7bkVcB7ZDVTvn3EkABwTc4HcWDfF1xT RUNNING 0
antnode12 12D3KooWPRHUooxp2SUJhwpbVemwRqshdp6tp1rER8buchYZvyM4 RUNNING 0
antnode13 12D3KooWSd156akD3DCEJgHDEkNHDug8jBNejmDdjNXTGLg3p1j4 RUNNING 0
antnode14 12D3KooWDnmaDRb7GvBD2yfQbAaJnWXr5nvMsgqhTjeRprXBZwCQ RUNNING 0
antnode15 12D3KooWHMypFG3H2ZLo3oE7aztj9BExMxeKLAHaF1wm21msjXPu RUNNING 0
antnode16 12D3KooWFTtLe8cdJ1d6FwZQZTpyteNAzSTKaXjyVj4312GEAqth RUNNING 72
antnode17 12D3KooWQ6B6UaUQP6Q8FoLhsvLYF4bSZC1LyELxf1ZBs4YmPnrb RUNNING 35
antnode18 12D3KooWHsmy2yDTZj9eEnUEhCgqohGBsZoTJvmms6JeJfcfjvCX RUNNING 21
antnode19 12D3KooWGYk836v4pGJTJtrLcCJAXNPx4dpG891xttDFvPvU4hXU RUNNING 42
antnode20 12D3KooWExutJhbGqEXwbCxheFUiWGMieNQxvWaeRJhdoqfRVFs8 RUNNING 72
antnode21 12D3KooWFNFDXGsCkQCkBAWbAXcKS6SUU9omHHcS5NfSfLr7k2k7 RUNNING 0
antnode22 12D3KooWCp2zeixSxSAXXba76TycqXtSUS9FkXhp3RxYeyKSgGTJ RUNNING 0
antnode23 12D3KooWMgrETHijXneRWcMQFwDLQVM5uasQGCRNygapZezT2NFH RUNNING 0
antnode24 12D3KooWHu7qtbRjJxmQZ1jCxGH8583FUNEjiSfpr3GPEeU59rZV RUNNING 0
antnode25 12D3KooWGZULnzXWbcPhhJm9mMoGTc36R6owLYCW5zjHFAcUrbay RUNNING 0
antnode26 12D3KooWLmCdUsHSdbWDcPUtYpqDHeKHBJUQmHzQ6S7CNArpbq3J RUNNING 0
antnode27 12D3KooWJ2eFLeZCAyd4mj2NwgZ6ohfdAHs7gtDoLCzLXacEUXkJ RUNNING 0
antnode28 12D3KooWFDMoppvjbKD9hu1FSngrgj7npVcoH7jw2babeGxPpraY RUNNING 0
antnode29 12D3KooWAT1awfVzhMF7S9pmk8q42LbbdVAGGsYiSGyo3VW68yCd RUNNING 0
antnode30 12D3KooWJAXethnxEZbckEC7AnQuStYPL8L2QA6PjWtHw4q5VGvm RUNNING 0
antnode31 12D3KooWLMMDcMJCwBXsgysWJjvjL2D1B5Q2FmfkPxWw7swf2ZLg RUNNING 0
antnode32 12D3KooWPjfU371M583aZ67FtYytvswf8PWC29SDtUG2a6Pif7qB RUNNING 0
antnode33 12D3KooWCvDFyiZCMQoRFDvRGHkCXKaiuWrWjGqDrNkm1P9qZCDc RUNNING 0
antnode34 12D3KooWCPV3ZekGSURc2aDYzD4iSfmgBfXqxzyCSK35NoDnHWYS RUNNING 0
antnode35 12D3KooWJMvp65ZQJY56MoF1LNbWPK2h2Coa9Pr7dN5txf9fUrFi RUNNING 0
antnode36 12D3KooWJtJu7UbH6RWGv3jEMmrtxQp3cpjpGgvu5EzYK6y65y99 RUNNING 0
antnode37 12D3KooWCo3vFMAkzMAdPtbncDngnmk6mSQPVLRH2P1mygRPcvf6 RUNNING 1
antnode38 12D3KooWGWVWVDrAxyQ4BQgL1GMEHNrqSSfLQxrGzumyLKfm5f2u RUNNING 2
antnode39 12D3KooWGWUPuAxwmN63q87VHH93UnJJpN2w8Fr4oG5npQmXJqMC RUNNING 0
antnode40 12D3KooWBoyHQ1ZsfdhFninEXkXpumfVRSFJcHk3YaL2seXLziB1 RUNNING 54
antnode41 12D3KooWLbEeQ4yCpXFU9ywxh9aRnfoKHSMdPmWR1MSyurcwsZ1H RUNNING 78
antnode42 12D3KooWC2RVMKFghmvSu3V6Ha191avc9AhcDq6bk9MEkhB8mhhn RUNNING 371
antnode43 12D3KooWLov3G4GDmzJi5be8pSvzZTaJBwvNrwqSLvQrwUt41bcs RUNNING 149
antnode44 12D3KooWGKwAg7FHuujUK3v5GxsNqRsME1Mp59KZF7v1ndhC21QP RUNNING 282
antnode45 12D3KooWNw49nxucVSbNP8gPPxBRJyRDTUbsopB8GkDCD7wQ77x5 RUNNING 227
antnode46 12D3KooWASkzTFaiRgrffbj5jCcd2G45DuLEttPp7ofer9U84oeL RUNNING 1033
antnode47 12D3KooWMAHunngAdooL3iyn7ntdncTyby34Vt6TRuXRGfY8gFoF RUNNING 1081
antnode48 12D3KooWQwyEBj4nohXfF6DJD8okdDQoZMNusyRgmMPAuLjmTgxM RUNNING 988
antnode49 12D3KooWAcufFQNHhgiJB3AYaXoupHi7twe3C8RSYBkHCkkWQGoo RUNNING 801
antnode50 12D3KooWMpgc1g28yaB4sHGq6kicsj5EXnFhWmLZBDRoV5LK4FPC RUNNING 598
Forward all UDP, home network, node ip set, starting node every 15s.
records: 2
conns:
antnode1 12D3KooWQBjn64Mff6mRTpBi3DA12mt8FzFq2YPyF7ijmWzLhJsX RUNNING 10
antnode2 12D3KooWKgkSizQK1JfZcr2P4qUiaWdfnUaYiEXCjXvV2ogUTsY5 RUNNING 7
antnode3 12D3KooWRsEcBE6cBoDATi3RCPZ4gtf8Q1ToKBDCtTfavUXssuWn RUNNING 8
antnode4 12D3KooWFsnr311rVuTJgFeuHwUwofw9XrcfdsgsZmNacuviMtb5 RUNNING 11
antnode5 12D3KooWGN5QnH2wqtrNPFTLbX74iHhdjDjpUPzGvVfwLDRYLBWw RUNNING 9
antnode6 12D3KooWQGsBBN5BE5ZWeLS8YdqqC8etVX4kwoiPFc4qb7ibeWLG RUNNING 15
antnode7 12D3KooWSazx2rtLyyeASg4qFQoh2yHTL8FRYChtreKK2PhPLqfe RUNNING 8
antnode8 12D3KooWFgiVRJzTpW4V9CsnK5t2qet9tbmC1P4tJiWnNYqRE8bR RUNNING 13
antnode9 12D3KooWSyYX1fcSNTz6buKDDdGPq3hL778J394nMbAP4J3KPhLH RUNNING 15
antnode10 12D3KooWKbkfexy4sCHxgWvpYquwWvoCYRh8RyxRBDoEnjiuVtW3 RUNNING 14
antnode11 12D3KooWRUX5NhkZ5NLFpAothuBVhHv6qRVYGYendsiN6JoQHexy RUNNING 21
antnode12 12D3KooWHHZyet52FypnFBMivzR7EYJF9iqvEtboP4AsU2Pc23sP RUNNING 19
antnode13 12D3KooWBCAoPC8e9s1fNVPJRBZ7ixVkwzvxvbVdaxJrTMc3cBQh RUNNING 20
antnode14 12D3KooWFV8rsojZsxwknAnVt5nnXZrvJda8eCVbZA2Gjpbzj2Mg RUNNING 58
antnode15 12D3KooWJxL1gqqM1crM8yT2MaohJQ9XZdtPFBJJ4hWtzRdYKfVT RUNNING 24
antnode16 12D3KooWScsMTgm4Ym6m29WekB5tM2CVBgcVJ7fEFMLHFZdtxHrY RUNNING 51
antnode17 12D3KooWRB4GTyi2fpebfXvy89M8XStFj5FXF3rpNnEjaMTLHuV1 RUNNING 12
antnode18 12D3KooWMGG7NqiHnzpFurn63wos4mbuYFGNrQDDGb1fJGtwXxRc RUNNING 27
antnode19 12D3KooWQAL9qsn5YdBams8DMEH4iWV3sd6z3MzEfcXv26Ry8upk RUNNING 86
antnode20 12D3KooWJUJHvHX8Scefb1DZC9Lfyb6c4AZWH4MjUMfE3VkbP2MS RUNNING 30
antnode21 12D3KooWPJoyoFdQdTvM8sRrWaBonpQZUKivKWWCi44jpCiK1zWz RUNNING 7
antnode22 12D3KooWDZVsMqEHmPNEGnx9iLq51YxuSR38wD1HK9bzR39rMw31 RUNNING 6
antnode23 12D3KooWJrMaSKHp8xMM2Vd92fnTA9ddKCCh54rabnjZa1XS1xEb RUNNING 7
antnode24 12D3KooWACnyvzWdBZwtoFmcRqy2wmxQYCwRbwh74eL4YS67mxmE RUNNING 13
antnode25 12D3KooWRoZNJbUxwkEnjyUAaK9ae73kdsgztjwjDFQQqnCMaXNS RUNNING 7
antnode26 12D3KooWJykmRvREk3W51qmRUY6B5b3foACdUm4RQMUGvTanzSyU RUNNING 12
antnode27 12D3KooWBeEe3xpu8RtvDTDg67YZGu5mUeMiD7dd9ZTKXRrgKH2v RUNNING 13
antnode28 12D3KooWCw6HK2NEb8NzVgxmN2gLq7QQweALpVYPLXeAF8M4yMaC RUNNING 9
antnode29 12D3KooWFxuUwML3XTjm87pHZHmaCxZQcX6GBJat2Ujx2jYUgXdv RUNNING 18
antnode30 12D3KooWEKv2RD9X6DguDmpdxN3RuRbiTpea3c9UUjVUYzdvAcYP RUNNING 9
antnode31 12D3KooWRijpngWLV1PMrpapTFrPwcFjpXFsU27fUwtTsimwVwut RUNNING 5
antnode32 12D3KooWB3GGhL6tWgvPcVNqXjGDujWcjTMiQeJVQRgXrm328W6i RUNNING 12
antnode33 12D3KooWBsEXorBZSyv8VKMhVEE8SLq3vYdr72xoXqLG2dupNzeK RUNNING 14
antnode34 12D3KooWHkQzAnqHzp8WBy9BX6EKXwtRnDbdFrfvhHFjzeUEVG8b RUNNING 7
antnode35 12D3KooWFyaFDui5Tp7VLr5FLXm55jsENxr74xQERthcaLzaN6zp RUNNING 8
antnode36 12D3KooWE9tiHFTBWoYyxzUqzNNmciFeqPhU9qbEWr2ZP5RGD3Ai RUNNING 8
antnode37 12D3KooWRb4VGeXQoM2VT2FXZeuhga6BCYZT89XDy8YGo5G1dXYa RUNNING 7
antnode38 12D3KooWF8NzXhQcPzzuSvYGoKLhQJfb3R1w2g7c2jUitLJX1kZf RUNNING 5
antnode39 12D3KooWDFoKgnNxtH3jowHvUTPxdokiiveTH1ayj7iPudvjtkJT RUNNING 9
antnode40 12D3KooWRnKHy2RkxRibH21woQwRsJuDezy1SBwvSAxpnwcwoXXW RUNNING 38
antnode41 12D3KooWRtbucppQrYbQ3CaSc3dyfyQBZD8v3Lb7KMgarKZtHDe8 RUNNING 716
antnode42 12D3KooWJ8oRS3mZeXBxWBhKgnGHAX3j84EJoeMJbGZGnRXkDeSQ RUNNING 518
antnode43 12D3KooWJ8StAwbg7ByPP8BPG2pgNmFrcHiorFYE2dPHBCSkxGf6 RUNNING 731
antnode44 12D3KooWJx2kqf2pE9tGFFDFYqs1qbWjDLYSRpdwr7kUuPy2GqsF RUNNING 854
antnode45 12D3KooWERMz2d1f8MPYw1mX8ZuAAqM2b2FKp3sbDPTe7szB8Err RUNNING 777
antnode46 12D3KooWKfWA4CCTTZBY3hm5vvXthRpSc2RRMsrHsWwR93NmhCyC RUNNING 802
antnode47 12D3KooWKW6RebfyS5GxCeQcYDvrkmBq4NGCxiertDwfxvUMurTW RUNNING 566
antnode48 12D3KooWAm6hBjeKqFxP6poC4zJRKGVgguLMFsdSh8tiBTGqTN2d RUNNING 424
antnode49 12D3KooWNgz3i81KDatGJwX3w24UaHQ92LWE7HrYzkLwptUYoXoH RUNNING 790
antnode50 12D3KooWQFKj1tkH57HDs8DmrRemFChWtYsfLhP85pFrdaoFqsDE RUNNING 545
Forward no UDP, home network, node ip set, starting node every 15s.
records: 2
conns:
antnode1 12D3KooWDavo1Jide2H5nKk4kst5EWavma5s4SDjoTkfHw9ELV2F RUNNING 17
antnode2 12D3KooWKhNfS3Gb1zeZjBExmbxw3qWPh5f6XRTyR8FXVwnaKqjc RUNNING 9
antnode3 12D3KooWPeR4oqpgT353ZXKUj2haNPyRjSdbEL38hfoBmHtRbDh7 RUNNING 5
antnode4 12D3KooWAmUkFrdvo3uZFCc2Q13vYGQZWzHbaVWF7vmmqFgJaazp RUNNING 7
antnode5 12D3KooWQiSYaoBqErtXLMRt6GjM5jTjwGDae75je94o2wDpAW6c RUNNING 13
antnode6 12D3KooWSyBTboYR9gQPW4H7REF5QkdkHm6dsV8afUyHPQgc4AUy RUNNING 12
antnode7 12D3KooWMyDLkmYgUtw5nMG5vBvWHtMDtisknE6QfcUcH5Xdvi17 RUNNING 17
antnode8 12D3KooWCE3PFXGQgFiR7C6FZ5siJooT8vAkW9SNLimqtobvxjMC RUNNING 16
antnode9 12D3KooWQBFawKD8hoT7mveNANzd7v1i1FHsewPqTHb2zfFGpRSU RUNNING 17
antnode10 12D3KooWLfLc4yWvEgSXrsJk5qT3gGRVU4qPhxEjhDi3x398BNME RUNNING 8
antnode11 12D3KooWR3GC5aqQd6gXms1xFLU57eUoi85PyJSTBDxaqyKsuKKy RUNNING 23
antnode12 12D3KooWPiGBcLDzYkraGAi1n16VUTEJt7VYPPovijnNHgQ1bRFH RUNNING 14
antnode13 12D3KooWRk6EsyoA8kiNwWmPGg2oLydtXDyvHVkgwhViJrSxE3E9 RUNNING 13
antnode14 12D3KooWBo9MBUQayEoTbWjURXB8N7VtSybPxiiKSNuHmBJ2Gyug RUNNING 21
antnode15 12D3KooWL8Kgnv7P9teLWmQgHwBsp4o4W7GU5E89WVAMh6uMZxJW RUNNING 40
antnode16 12D3KooWR9LMHQ5HcNx4tZNPLBmU79VndREQL8MR6PvWYP4xwFzu RUNNING 28
antnode17 12D3KooWPYbagCTm94FoJ3JHJLv9VhZWjYJCv6Qna6rdynJVLXH3 RUNNING 9
antnode18 12D3KooWCA2VRTvRtDfD8ghJti4xgSjyhCGg6BXYUsayqg5gKteE RUNNING 36
antnode19 12D3KooWHjydnXygTShcDxSw1F3iKYF5xekBVjmTC9UCVsFGpeCZ RUNNING 10
antnode20 12D3KooWEbx8f86Sd5E8WiE9Zsc9Ej2cQt4KgvWwx8322Eqv2sD6 RUNNING 8
antnode21 12D3KooWHW4pX9EmhAYURK7yaVtiuuWdFwepKgWJifP7xWf2JH2M RUNNING 9
antnode22 12D3KooWRrbEKx8Nox4U2M5dfMZoGhQGHixAzAjAjacAgNZPCXT5 RUNNING 9
antnode23 12D3KooWGwYM7AMZHMBkyQYyZqUvdutq4KGMuoQE1Cq6TN4S79ye RUNNING 10
antnode24 12D3KooWAGGpu5qhyEVkFJW7YZWeBEcTbFT4HqmLqsWqyPYd7ymy RUNNING 6
antnode25 12D3KooWNjVUnp1jCrFpKRupUeXYtbAmnhTeKCFCfyj65PeCfBV8 RUNNING 8
antnode26 12D3KooWFqLWMxZNqZFMtaTGQfaSKugiJKkRPuXJaffZGJB7Yk4X RUNNING 5
antnode27 12D3KooWEY5B9WKHcpDf51DowKv4S4x8cfiTuneAjQFgvYQjfp8m RUNNING 6
antnode28 12D3KooWR5Tz6xzZjxcH9PLuW9WBMv7mydzZ6AHm3PXcziPgSbjz RUNNING 9
antnode29 12D3KooWP69HrtHxnxrx4BxmZqVzYV5pi3r8A9qdfNqW6eYFDQCZ RUNNING 7
antnode30 12D3KooWDpyjy4qNTCQYW6u2amEbbY4h6QUpFbZMFmTrmr5phjyr RUNNING 11
antnode31 12D3KooWDArzyobFNLqeEciizniAQgJFUqUaLihLBbcLhrK5EjTb RUNNING 8
antnode32 12D3KooWPMCKbVwAir1P78kgwqHivFxprU7aMWviYfmy5v7W6nLT RUNNING 9
antnode33 12D3KooWFTvTtR9yXGWqQsdKoLM3sR6W7M6xiFj9EvKdATiBmHJ8 RUNNING 13
antnode34 12D3KooWE7U1bWHq9C4BpwJm8jV9TpNqr7YRTEtDJ71uWj4ugFkv RUNNING 4
antnode35 12D3KooWCLZMLkFcB9ER7AkqMD5wH5NRahfB6o9hALqyfBCpUn9X RUNNING 5
antnode36 12D3KooWPyTM7avGm3qBHqshbzTigJQEumtGBgjtrS1s5vm6hwb8 RUNNING 9
antnode37 12D3KooWNiVLBxVxzh5txDEp3yV5Ekr4ggutDtUMVYuZGEymbhPu RUNNING 8
antnode38 12D3KooWJZbewTVC68rrijHwYQMzhxiNggWeEM4dksCJeedbmBFK RUNNING 8
antnode39 12D3KooWDExRBmkZcidDcRGmg8RipD7u2ihccANR6Gf3se4qLBPC RUNNING 8
antnode40 12D3KooWENaVhdZrPADQNnV8Skw1yho2vSyt9Nuz5CvSHupoxcBm RUNNING 283
antnode41 12D3KooWBhmCPipehGVUnraGEnENWNGpdietoAZvsAeEfdzZpSNC RUNNING 443
antnode42 12D3KooWAhQEgmnCT6d6aSV4Qq4hJjzzSN8CC3ceZgUkLMNHtCgr RUNNING 614
antnode43 12D3KooWSuXqrJags1MNbDoapd3Ww2pTUaERxsN8x1Aa9EcEX7p5 RUNNING 872
antnode44 12D3KooWMGdDmz5j3j35WzGNfycjYmGcwjG5LjP12FVXhiBjHnUq RUNNING 619
antnode45 12D3KooWRgLeFFftNt56qFZ6CsTyNpTVwmSwps6okpXXhyHdRNKo RUNNING 768
antnode46 12D3KooWSVxyxWBKYxAjt8HkhoHbxyWDAF2crpdfzM2U13qstSpC RUNNING 800
antnode47 12D3KooWLCXUP5RjfRxaSFc4XUgg74Np2DAbiR3Cwkq2m6EsASnN RUNNING 563
antnode48 12D3KooWHxK3jBikHgyxd9oSZWco5Gugi7qKYkPyiTW3jMMxVSSK RUNNING 363
antnode49 12D3KooWR53TnGBCTjcNYHCzefpdqG7WNgVQHZfcBZAa2mG8M5oZ RUNNING 736
antnode50 12D3KooWB9a5Dy29YdhNmjLJ4v4BZpPK2gzSyGXYuL95TUPMheHK RUNNING 591
Setting --node-ip did double or more the throughput I observed nodes using, so I would say yes. And ‘yes’ re: multiple NICs, specifically the physical NIC and the wg0 interface that traffic needed to go out/in over.
system
Closed
April 11, 2025, 7:17am
28
