if you’re seeing OutOfOrder errors, do a fresh keys create for the CLI to get going again
Is it possible to post this with trace logs? ie try running
RUST_LOG=safe_network=trace safe files put BegBlagandSteal.mp3
edit: sorry see you already have been requested and then posted the result just as I put this!!
with trace
administrator@Test-Node:~/Desktop$ RUST_LOG=safe_network=trace safe files put safe-the-planett.png
[safe_network::client::client_api] INFO 2021-06-30T09:35:53.893931700 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/mod.rs:85] Client started for specific pk: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b)
[safe_network::client::config_handler] WARN 2021-06-30T09:35:53.894259410 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/config_handler.rs:73] Failed to open config file from '/home/administrator/.safe/client/sn_client.config': No such file or directory (os error 2)
[safe_network::client::config_handler] DEBUG 2021-06-30T09:35:53.894890099 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/config_handler.rs:50] Bootstrapping contacts overriden with: {209.97.176.123:55911, 209.97.138.128:59206, 209.97.176.93:57677, 139.59.178.75:57133, 209.97.141.103:52713, 167.99.198.192:56527, 209.97.176.98:39100, 178.128.40.158:42845, 209.97.176.134:53102, 209.97.176.97:60599, 209.97.141.179:39630, 209.97.133.206:38243, 159.65.27.95:56248, 209.97.131.245:49877, 209.97.176.91:33956, 209.97.176.138:59795, 209.97.176.127:55047, 159.65.94.13:57349, 206.189.123.106:43685, 209.97.133.247:48201, 209.97.131.130:35410, 209.97.140.34:59824, 209.97.176.100:54768, 209.97.176.145:57380, 46.101.6.111:40836, 206.189.127.108:51563, 46.101.95.158:12000, 206.189.125.78:60401, 209.97.143.117:42097, 209.97.129.240:48304, 209.97.176.99:50115, 209.97.138.80:34447, 209.97.133.65:40289}
[safe_network::client::connections] DEBUG 2021-06-30T09:35:53.895283070 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/mod.rs:65] QP2p config: Config { hard_coded_contacts: {209.97.176.123:55911, 209.97.138.128:59206, 209.97.176.93:57677, 139.59.178.75:57133, 209.97.141.103:52713, 167.99.198.192:56527, 209.97.176.98:39100, 178.128.40.158:42845, 209.97.176.134:53102, 209.97.176.97:60599, 209.97.141.179:39630, 209.97.133.206:38243, 159.65.27.95:56248, 209.97.131.245:49877, 209.97.176.91:33956, 209.97.176.138:59795, 209.97.176.127:55047, 159.65.94.13:57349, 206.189.123.106:43685, 209.97.133.247:48201, 209.97.131.130:35410, 209.97.140.34:59824, 209.97.176.100:54768, 209.97.176.145:57380, 46.101.6.111:40836, 206.189.127.108:51563, 46.101.95.158:12000, 206.189.125.78:60401, 209.97.143.117:42097, 209.97.129.240:48304, 209.97.176.99:50115, 209.97.138.80:34447, 209.97.133.65:40289}, local_port: None, local_ip: None, forward_port: true, external_port: None, external_ip: None, max_msg_size_allowed: None, idle_timeout_msec: None, keep_alive_interval_msec: None, bootstrap_cache_dir: Some("/home/administrator/.safe/client"), upnp_lease_duration: None }
[safe_network::client::client_api] DEBUG 2021-06-30T09:35:53.896488311 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/mod.rs:115] Bootstrapping to the network...
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:53.896742281 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:36] Trying to bootstrap to the network with public_key: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b)
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.130515460 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:481] Querying for section info from bootstrapped node: 209.97.141.103:52713
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.209138097 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.141.103:52713
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.210189885 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:107] Handling network info message GetSectionResponse(Success(SectionAuthorityProvider { prefix: (1), section_key: PublicKey(0744..cc17), elders: {(8b8f5a(10001011).., 159.65.27.95:56248), (b84ea1(10111000).., 209.97.133.247:48201), (d477c2(11010100).., 209.97.141.103:52713), (d6dc8d(11010110).., 209.97.176.145:57380), (d98cc0(11011001).., 209.97.176.91:33956), (e7e7d8(11100111).., 209.97.176.138:59795), (e9eb29(11101001).., 209.97.138.128:59206)} }))
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.211799813 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:111] GetSectionResponse::Success!
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.213160966 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:181] Updating session info! Received elders: ({159.65.27.95:56248: 8b8f5a(10001011).., 209.97.133.247:48201: b84ea1(10111000).., 209.97.138.128:59206: e9eb29(11101001).., 209.97.141.103:52713: d477c2(11010100).., 209.97.176.91:33956: d98cc0(11011001).., 209.97.176.138:59795: e7e7d8(11100111).., 209.97.176.145:57380: d6dc8d(11010110)..})
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.213443574 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:209] Connecting to new set of Elders: {159.65.27.95:56248: 8b8f5a(10001011).., 209.97.133.247:48201: b84ea1(10111000).., 209.97.138.128:59206: e9eb29(11101001).., 209.97.141.103:52713: d477c2(11010100).., 209.97.176.91:33956: d98cc0(11011001).., 209.97.176.138:59795: e7e7d8(11100111).., 209.97.176.145:57380: d6dc8d(11010110)..}
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.215058022 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:524] We now know our 7 Elders.
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.215671992 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:43] Listening for incoming messages
[safe_network::client::connections::messaging] DEBUG 2021-06-30T09:35:54.216141226 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:105] Successfully obtained the list of Elders to send all messages to: [159.65.27.95:56248, 209.97.133.247:48201, 209.97.138.128:59206, 209.97.141.103:52713, 209.97.176.91:33956, 209.97.176.138:59795, 209.97.176.145:57380]
[safe_network::client::client_api] WARN 2021-06-30T09:35:54.217267732 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/mod.rs:164] No automatic simulated payout occurs for clients created for pre-existing SecretKeys
[safe_network::client::client_api::transfers] INFO 2021-06-30T09:35:54.217412359 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:120] Getting SnTransfers history for pk: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b)
[safe_network::client::client_api::queries] DEBUG 2021-06-30T09:35:54.217918312 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/queries.rs:23] Sending Query: Transfer(TransferQuery::GetHistory)
[safe_network::client::connections::messaging] INFO 2021-06-30T09:35:54.218121775 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:310] Sending query message Process(Query { id: 6f8339fc.., query: Transfer(TransferQuery::GetHistory), client_sig: ClientSig { public_key: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b), signature: Signature::Ed25519(..) } }), to the 3 Elders closest to data name: [209.97.176.138:59795, 209.97.138.128:59206, 209.97.141.103:52713]
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.218353899 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:322] Inserting channel for 6f8339fc..
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.241713799 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 6f8339fc.., sent to 209.97.141.103:52713
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.242125936 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 6f8339fc.., sent to 209.97.138.128:59206
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.242415061 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 6f8339fc.., sent to 209.97.176.138:59795
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.274136787 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.141.103:52713
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.274307643 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 4e7fbf7f.. received from 209.97.141.103:52713
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.285633244 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.176.138:59795
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.285696506 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 4e7fbf7f.. received from 209.97.176.138:59795
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.285826215 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.285862124 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 6f8339fc..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.285948830 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetHistory(Ok(ActorHistory { credits: [CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..)], debits: [] }))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.285986440 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:255] Sending response for query w/6f8339fc.. via channel.
[safe_network::client::connections::messaging] DEBUG 2021-06-30T09:35:54.286032968 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:440] QueryResponse received is: GetHistory(
Ok(
ActorHistory {
credits: [
CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..),
debits: [],
[safe_network::client::connections::messaging] DEBUG 2021-06-30T09:35:54.286082130 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:453] Response obtained for query w/id 6f8339fc..: Some(GetHistory(Ok(ActorHistory { credits: [CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..)], debits: [] })))
[safe_network::transfers::actor] DEBUG 2021-06-30T09:35:54.286138741 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/transfers/actor.rs:429] Transfer Actor PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b): applying event TransfersSynched(TransfersSynched(ActorHistory { credits: [CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..)], debits: [] }))
[safe_network::client::client_api::transfers] DEBUG 2021-06-30T09:35:54.286179029 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:153] Current balance after GetHistory 1000.111000000
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.290587920 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:460] Removing channel for 6f8339fc..
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.296327972 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.296389906 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 4e7fbf7f.. received from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.296452422 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.296641048 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 6f8339fc..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.296682091 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetHistory(Ok(ActorHistory { credits: [CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..)], debits: [] }))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.296741069 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:261] No channel found for 6f8339fc..
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.296527766 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.296826982 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 6f8339fc..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.296927199 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetHistory(Ok(ActorHistory { credits: [CreditAgreementProof::Credit(1000.111000000)ActorSignature::Signature::Bls(..)ReplicaSignature::Signature::Bls(..)], debits: [] }))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.296960357 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:261] No channel found for 6f8339fc..
[safe_network::client::client_api::blob_storage] TRACE 2021-06-30T09:35:54.301408114 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/blob_storage.rs:94] Self encrypt invoked StoreChunk(Public(PublicChunk c0189e(11000000)..))
[safe_network::client::client_api::transfers] INFO 2021-06-30T09:35:54.301479089 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:198] Sending requests for payment for write operation
[safe_network::client::client_api::transfers] INFO 2021-06-30T09:35:54.301613811 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:160] Sending Query for latest StoreCost
[safe_network::client::client_api::queries] DEBUG 2021-06-30T09:35:54.301765033 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/queries.rs:23] Sending Query: Transfer(TransferQuery::GetStoreCost of 19220)
[safe_network::client::connections::messaging] INFO 2021-06-30T09:35:54.301844636 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:310] Sending query message Process(Query { id: 3eca9b51.., query: Transfer(TransferQuery::GetStoreCost of 19220), client_sig: ClientSig { public_key: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b), signature: Signature::Ed25519(..) } }), to the 3 Elders closest to data name: [209.97.176.138:59795, 209.97.138.128:59206, 209.97.141.103:52713]
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.302039956 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:322] Inserting channel for 3eca9b51..
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.324417146 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 3eca9b51.., sent to 209.97.176.138:59795
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.324417133 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 3eca9b51.., sent to 209.97.138.128:59206
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.324682951 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:350] ClientMsg with id: 3eca9b51.., sent to 209.97.141.103:52713
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.325935685 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.141.103:52713
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.325979293 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id cd3a5691.. received from 209.97.141.103:52713
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.326024804 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.326064749 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 3eca9b51..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.326092008 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetStoreCost(Ok((19220, 0.000057414, PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf))))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.326261958 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:255] Sending response for query w/3eca9b51.. via channel.
[safe_network::client::connections::messaging] DEBUG 2021-06-30T09:35:54.326718424 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:440] QueryResponse received is: GetStoreCost(
Ok(
19220,
0.000057414,
PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf),
was to much for one message
[safe_network::client::connections::messaging] DEBUG 2021-06-30T09:35:54.326780559 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:453] Response obtained for query w/id 3eca9b51..: Some(GetStoreCost(Ok((19220, 0.000057414, PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf)))))
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.326868595 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:460] Removing channel for 3eca9b51..
[safe_network::client::client_api::transfers] TRACE 2021-06-30T09:35:54.327072807 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:177] Cost of put returned was: 0.000057414
[safe_network::client::client_api::transfers] TRACE 2021-06-30T09:35:54.327103722 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:185] Payment buffer applied if possible, paying: 0.000086121
[safe_network::client::client_api::transfers] INFO 2021-06-30T09:35:54.327131628 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:204] Current store cost for 19220 bytes reported by section PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf): 0.000086121
[safe_network::client::client_api::transfers] DEBUG 2021-06-30T09:35:54.327302553 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:223] Transfer to be sent: SignedTransfer { debit: SignedDebit { debit: Debit { id: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b).0, amount: 0.000086121 }, actor_signature: Signature::Ed25519(..) }, credit: SignedCredit { credit: Credit { id: [102, 100, 51, 109, 214, 168, 130, 198, 102, 40, 24, 155, 134, 133, 97, 228, 129, 117, 252, 173, 189, 81, 93, 65, 134, 194, 231, 239, 151, 185, 140, 237], amount: 0.000086121, recipient: PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf), msg: "" }, actor_signature: Signature::Ed25519(..) } }
[safe_network::transfers::actor] DEBUG 2021-06-30T09:35:54.327397528 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/transfers/actor.rs:429] Transfer Actor PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b): applying event TransferInitiated(TransferInitiated { signed_debit: SignedDebit { debit: Debit { id: PublicKey::Ed25519(f07c6e38760fb727f48ee20032f6bee4ef3933c97bfa68d8e1833e25517fe07b).0, amount: 0.000086121 }, actor_signature: Signature::Ed25519(..) }, signed_credit: SignedCredit { credit: Credit { id: [102, 100, 51, 109, 214, 168, 130, 198, 102, 40, 24, 155, 134, 133, 97, 228, 129, 117, 252, 173, 189, 81, 93, 65, 134, 194, 231, 239, 151, 185, 140, 237], amount: 0.000086121, recipient: PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf), msg: "" }, actor_signature: Signature::Ed25519(..) } })
[safe_network::client::client_api::transfers] INFO 2021-06-30T09:35:54.327475828 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/client_api/transfers/mod.rs:246] Awaiting transfer validation
[safe_network::client::connections::messaging] INFO 2021-06-30T09:35:54.327552582 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:206] Sending transfer validation command Transfer(TransferCmd::ValidateTransfer) w/ id: 49f1f36d..
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.327648084 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 159.65.27.95:56248
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.327792329 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.133.247:48201
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.327988634 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.138.128:59206
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.328186031 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.141.103:52713
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.328349879 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.176.91:33956
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.328516808 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.176.138:59795
[safe_network::client::connections::messaging] TRACE 2021-06-30T09:35:54.328703880 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/messaging.rs:239] Sending transfer validation to Elder 209.97.176.145:57380
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.329532899 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.329579335 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id cd3a5691.. received from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.329640161 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.329676404 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 3eca9b51..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.329712309 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetStoreCost(Ok((19220, 0.000057414, PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf))))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.329757950 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:261] No channel found for 3eca9b51..
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.332235394 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.176.138:59795
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.332270877 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id cd3a5691.. received from 209.97.176.138:59795
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.332301834 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.332321025 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:246] Query response (relating to msgid: 3eca9b51..)
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.332348522 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:248] The received query response is GetStoreCost(Ok((19220, 0.000057414, PublicKey::Bls(a744cac5d0440ef62d659ddeb08d11cc9d0971327260cfc16b3ea882242ed7bf))))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.332384513 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:261] No channel found for 3eca9b51..
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.360626808 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.176.91:33956
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.360685014 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.176.91:33956
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.361268140 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.133.247:48201
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.361311490 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.133.247:48201
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.361369108 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.361407203 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.361441875 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.361473227 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.361504842 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.361444568 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.364800464 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.176.145:57380
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.364837396 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.176.145:57380
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.364867755 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.364887986 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.364915825 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.367447532 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.176.138:59795
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.367497336 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.176.138:59795
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.368043845 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368082146 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368242977 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368278140 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.368307332 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.368767165 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 209.97.141.103:52713
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368806142 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 209.97.141.103:52713
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368858284 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368903840 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.368948564 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.368924576 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.369027554 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.369057452 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] TRACE 2021-06-30T09:35:54.372299278 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:71] Incoming message from 159.65.27.95:56248
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.372335676 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:232] ClientMsg with id 7e9d701e.. received from 159.65.27.95:56248
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.372375655 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T09:35:54.372403182 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:292] CmdError was received for Message w/ID: 49f1f36d.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T09:35:54.372424085 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/safe_network-0.4.0/src/client/connections/listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
File upload crashes also for Windows 7.
So it is not OS specific.
Another attempt with different file - hang instead of crash.
@joshuef @mav
Its not ubuntu 20.04 specific
as I have a separate ubuntu box running 20.04 in a different location I ssh’ed in and I can successfully put a file from that box.
0000000140060C8E adox r9,rdi
“Intel ADX was first supported in the Broadwell microarchitecture”
Safe Network have no support for my Haswell i5-4690 ![]()
For those experiencing the illegal instruction. (And fancy a bit of advanced debugging; this assumes you’d have rust isntalled)… Could you:
git clone https://github.com/supranational/blst.gitcd blst/bindings/rustcargo test --release
and then we can verify something about these rust bindings within blst. ![]()
Please look at my post above about ADX.
Is test still needed?
could that be my problem as well ?
@joshuef @Vort
I have ubuntu 20.04 running in virtual box on top of windows 10
on two separate machines.
the one that doesn’t work is running on an old i7-3667U
and the one that is working is running a new i7-10875H
It’d just confim that it’s blsst and not some other sneaky dep change eg.
It is Ivy Bridge. Even older than mine.
Current sn binaries will not work with it.
Anybody want to see japanese castle?
safe cat safe://hygoygycyrd89wzsm655nhe4swwaohaa7gfah5qpty1apwfnqw9cfxe3asw > ~/japan2.jpg
this mp3 is dedicated to @Southside
BegBlagandSteal.mp3 safe://hygyy1yj6rhwf5wooaz1wzikuk31mhg5pph75wfi83yz4gd9t9kjsjqnqcc
On windows (git-bash), trying to put a small (15Kb) .docx file:
RUST_LOG=safe_network=trace safe files put TORTA.docx
[safe_network::client::client_api] INFO 2021-06-30T19:03:33.039564300 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\client_api\mod.rs:85] Client started for specific pk: PublicKey::Ed25519(b95c1f2792f73ce384d2e30ac5458cf8be1323f6992de39d4d5ee1f155bbd5df)
[safe_network::client::config_handler] WARN 2021-06-30T19:03:33.060587400 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\config_handler.rs:73] Failed to open config file from 'C:\Users\Stefano\.safe\client\sn_client.config': The system cannot find the file specified. (os error 2)
lots more messages and then hangs; last messages:
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.595484100 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.595566400 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:292] CmdError was received for Message w/ID: b63ae7e8.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T19:23:10.595632500 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.599397200 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:232] ClientMsg with id a3016a9b.. received from 209.97.138.128:59206
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.599613400 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.599693100 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:292] CmdError was received for Message w/ID: b63ae7e8.., sending on error channel
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.599690000 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:239] Thread spawned to handle this client message
[safe_network::client::connections::listeners] DEBUG 2021-06-30T19:23:10.600119100 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:292] CmdError was received for Message w/ID: b63ae7e8.., sending on error channel
[safe_network::client::connections::listeners] WARN 2021-06-30T19:23:10.600195800 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
[safe_network::client::connections::listeners] WARN 2021-06-30T19:23:10.599771900 [C:\Users\runneradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\safe_network-0.4.0\src\client\connections\listeners.rs:296] CmdError received is: Transfer(TransferValidation(MissingTransferHistory(0, 1)))
Would it be a good thing if people pinned which OS and Hardware they are using when they post their problems?
I hope for hardware, OS limits until launch if needed, so we don’t get slowed down.
Let’s go, keep up the good work.
Is it possible that it checks architecture before building?
So newer CPUs will get binaries with adox, older - without it.
on my Virtual box running ubuntu 20.04 on top of windows 10 running on a old i7-3667U with illegal instructions
Using username "administrator".
Authenticating with public key "rsa-key-20191130"
Welcome to Ubuntu 20.04.2 LTS (GNU/Linux 5.8.0-59-generic x86_64)
* Documentation: https://help.ubuntu.com
* Management: https://landscape.canonical.com
* Support: https://ubuntu.com/advantage
2 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Your Hardware Enablement Stack (HWE) is supported until April 2025.
Last login: Wed Jun 30 10:00:58 2021 from 13.12.11.5
administrator@Test-Node:~$
administrator@Test-Node:~$ git clone https://github.com/supranational/blst.git
Command 'git' not found, but can be installed with:
sudo apt install git
administrator@Test-Node:~$ sudo apt install git
[sudo] password for administrator:
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following additional packages will be installed:
git-man liberror-perl
Suggested packages:
git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk gitweb git-cvs git-mediawiki git-svn
The following NEW packages will be installed
git git-man liberror-perl
0 to upgrade, 3 to newly install, 0 to remove and 2 not to upgrade.
Need to get 5,468 kB of archives.
After this operation, 38.4 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://gb.archive.ubuntu.com/ubuntu focal/main amd64 liberror-perl all 0.17029-1 [26.5 kB]
Get:2 http://gb.archive.ubuntu.com/ubuntu focal-updates/main amd64 git-man all 1:2.25.1-1ubuntu3.1 [884 kB]
Get:3 http://gb.archive.ubuntu.com/ubuntu focal-updates/main amd64 git amd64 1:2.25.1-1ubuntu3.1 [4,557 kB]
Fetched 5,468 kB in 1s (4,781 kB/s)
Selecting previously unselected package liberror-perl.
(Reading database ... 170266 files and directories currently installed.)
Preparing to unpack .../liberror-perl_0.17029-1_all.deb ...
Unpacking liberror-perl (0.17029-1) ...
Selecting previously unselected package git-man.
Preparing to unpack .../git-man_1%3a2.25.1-1ubuntu3.1_all.deb ...
Unpacking git-man (1:2.25.1-1ubuntu3.1) ...
Selecting previously unselected package git.
Preparing to unpack .../git_1%3a2.25.1-1ubuntu3.1_amd64.deb ...
Unpacking git (1:2.25.1-1ubuntu3.1) ...
Setting up liberror-perl (0.17029-1) ...
Setting up git-man (1:2.25.1-1ubuntu3.1) ...
Setting up git (1:2.25.1-1ubuntu3.1) ...
Processing triggers for man-db (2.9.1-1) ...
Cloning into 'blst'...
remote: Enumerating objects: 3261, done.
remote: Counting objects: 100% (775/775), done.
remote: Compressing objects: 100% (261/261), done.
remote: Total 3261 (delta 521), reused 751 (delta 504), pack-reused 2486
Receiving objects: 100% (3261/3261), 1.18 MiB | 939.00 KiB/s, done.
Resolving deltas: 100% (2250/2250), done.
administrator@Test-Node:~$ cd blst/bindings/rust
administrator@Test-Node:~/blst/bindings/rust$ cargo test --release
Updating crates.io index
Downloaded zeroize_derive v1.1.0
Downloaded zeroize v1.3.0
Downloaded threadpool v1.8.1
Downloaded either v1.6.1
Downloaded crossbeam-epoch v0.9.5
Downloaded bstr v0.2.16
Downloaded cast v0.2.6
Downloaded criterion-plot v0.4.3
Downloaded cc v1.0.68
Downloaded half v1.7.1
Downloaded num_cpus v1.13.0
Downloaded itoa v0.4.7
Downloaded criterion v0.3.4
Downloaded oorandom v11.1.3
Downloaded plotters-backend v0.3.1
Downloaded plotters-svg v0.3.1
Downloaded regex-automata v0.1.10
Downloaded semver-parser v0.10.2
Downloaded rustc_version v0.3.3
Downloaded serde_cbor v0.11.1
Downloaded serde_derive v1.0.126
Downloaded serde_json v1.0.64
Downloaded ucd-trie v0.1.3
Downloaded crossbeam-deque v0.8.0
Downloaded tinytemplate v1.2.1
Downloaded synstructure v0.12.4
Downloaded csv-core v0.1.10
Downloaded glob v0.3.0
Downloaded semver v0.11.0
Downloaded csv v1.1.6
Downloaded ryu v1.0.5
Downloaded pest v2.1.3
Downloaded itertools v0.10.1
Downloaded rayon-core v1.9.1
Downloaded rayon v1.5.1
Downloaded memoffset v0.6.4
Downloaded itertools v0.9.0
Downloaded plotters v0.3.1
Downloaded 38 crates (11.3 MB) in 3.00s (largest was `plotters` at 8.6 MB)
Compiling autocfg v1.0.1
Compiling libc v0.2.97
Compiling cfg-if v1.0.0
Compiling proc-macro2 v1.0.27
Compiling unicode-xid v0.2.2
Compiling ucd-trie v0.1.3
Compiling lazy_static v1.4.0
Compiling serde v1.0.126
Compiling crossbeam-utils v0.8.5
Compiling syn v1.0.73
Compiling memchr v2.4.0
Compiling ryu v1.0.5
Compiling crossbeam-epoch v0.9.5
Compiling scopeguard v1.1.0
Compiling rayon-core v1.9.1
Compiling either v1.6.1
Compiling getrandom v0.1.16
Compiling bitflags v1.2.1
Compiling serde_json v1.0.64
Compiling itoa v0.4.7
Compiling plotters-backend v0.3.1
Compiling glob v0.3.0
Compiling cc v1.0.68
Compiling regex-automata v0.1.10
Compiling unicode-width v0.1.8
Compiling serde_derive v1.0.126
Compiling same-file v1.0.6
Compiling ppv-lite86 v0.2.10
Compiling regex-syntax v0.6.25
Compiling half v1.7.1
Compiling oorandom v11.1.3
Compiling memoffset v0.6.4
Compiling num-traits v0.2.14
Compiling rayon v1.5.1
Compiling pest v2.1.3
Compiling itertools v0.9.0
Compiling itertools v0.10.1
Compiling plotters-svg v0.3.1
Compiling textwrap v0.11.0
Compiling walkdir v2.3.2
Compiling blst v0.3.4 (/home/administrator/blst/bindings/rust)
Compiling regex v1.5.4
Compiling semver-parser v0.10.2
Compiling num_cpus v1.13.0
Compiling atty v0.2.14
Compiling quote v1.0.9
Compiling semver v0.11.0
Compiling serde_cbor v0.11.1
Compiling crossbeam-channel v0.5.1
Compiling csv-core v0.1.10
Compiling bstr v0.2.16
Compiling clap v2.33.3
Compiling threadpool v1.8.1
Compiling rand_core v0.5.1
Compiling plotters v0.3.1
Compiling rustc_version v0.3.3
Compiling csv v1.1.6
Compiling tinytemplate v1.2.1
Compiling rand_chacha v0.2.2
Compiling crossbeam-deque v0.8.0
Compiling synstructure v0.12.4
Compiling cast v0.2.6
Compiling rand v0.7.3
Compiling zeroize_derive v1.1.0
Compiling zeroize v1.3.0
Compiling criterion-plot v0.4.3
Compiling criterion v0.3.4
Finished release [optimized] target(s) in 5m 53s
Running unittests (target/release/deps/blst-62f784672096ddab)
running 20 tests
test bindgen_test_layout_blst_fp ... ok
test bindgen_test_layout_blst_fp12 ... ok
test bindgen_test_layout_blst_fp2 ... ok
test bindgen_test_layout_blst_fp6 ... ok
test bindgen_test_layout_blst_fr ... ok
test bindgen_test_layout_blst_p1 ... ok
test bindgen_test_layout_blst_p1_affine ... ok
test bindgen_test_layout_blst_p2 ... ok
test bindgen_test_layout_blst_p2_affine ... ok
test bindgen_test_layout_blst_pairing ... ok
test bindgen_test_layout_blst_scalar ... ok
test bindgen_test_layout_blst_uniq ... ok
test min_pk::tests::test_aggregate ... ok
test min_pk::tests::test_serialization ... ok
test min_pk::tests::test_sign ... ok
test min_sig::tests::test_aggregate ... ok
test min_pk::tests::test_multiple_agg_sigs ... ok
test min_sig::tests::test_serialization ... ok
test min_sig::tests::test_sign ... ok
test min_sig::tests::test_multiple_agg_sigs ... ok
test result: ok. 20 passed; 0 failed; 0 ignored; 0 measured; 0 filtered out; finished in 0.99s
Doc-tests blst
running 0 tests
test result: ok. 0 passed; 0 failed; 0 ignored; 0 measured; 0 filtered out; finished in 0.00s
