I do not have a private key for the wallet address. I have joined the NVO Slack just now, but you are already in the middle of helping me here. How should I restart this conversation there?
I do have the wallet address however. But, as I said, it had disappeared and this has happened before with other folks.
I set the wallet up mid-way through the ICO. It is the regular bitcoin wallet on the Counterparty platform. The advice was to add additional (creating) wallet addresses until the wallet re-appeared. This I did several times, one time even adding eleven addresses. Yes, I should probably return to counterparty talk. Any other advice, please?
I see that to many of the inquiries, there are no replies there on counterpartytalk.org
Iāve sent you a private message on slack
Maybe try out this tool GitHub - iancoleman/bip39: A web tool for converting BIP39 mnemonic codes
Hey there,
I donated to NVO. I have a private key that I made via walletgenerator. I used that key inside Jaxx. i sent bitcoins every time via my jaxx wallet to NVO. On July fourth I received bitcoins. I donāt know why they would send me bitcoins? Do I need to take my private key to another wallet to see my NVO? Did I do something incorrectly?
You were sent a Counterparty asset (NVST) so you need a wallet that understands Counterparty assets to view them, or type your wallet address into https://xchain.io and you can see them there.
hi i dont have any tokens in my electrum wallet yet. Why ?
hi happy being. so how u recon i should get my nvst tokens?
Best talk to the NVO team. Try their Slack.
hi tonbi
i ntoiced i havent received any tokens in my electrum wallet. any reason why?
You canāt see the tokens on electrumā¦
send me the link please
yes
i have funded using ripple and eth but gave a paper wallet adress. That i then added to my electrum account.
can u help me out? im really confused. Some ICO s are really messed up.
@paulo, apparently electrum will not show you the NVO coins that are at any address. You need to check your balance at https://xchain.io
ok. i seen my balance there. so what u recommend i should do?
how do i sent eth i cant see my nvot using my btc address
i put my bitcoin address in xchain no record but my 2 eth are on the dashboard help.
how do i get an invite to the slack team to get my nvot
