New Release: Vault Phase 1 (real vault)
All users of the shared vault please note that this vault was restarted today and so the vault_connection_info.config file has been updated in the GitHub releases for the vault.
See the latest vault release here for the new vault_connection_info.config file - if you intend to use the shared vault you should download this to the relevant location for your platform, as per the OP.
Thanks.
I wanted to rebuild safe-cli and safe-authenticator-cli from source. It is OK for the former, but the latter doesn’t compile:
$ git clone https://github.com/maidsafe/safe-authenticator-cli.git
Cloning into 'safe-authenticator-cli'...
remote: Enumerating objects: 44, done.
remote: Counting objects: 100% (44/44), done.
remote: Compressing objects: 100% (32/32), done.
remote: Total 650 (delta 21), reused 22 (delta 12), pack-reused 606
Receiving objects: 100% (650/650), 354.21 KiB | 1.26 MiB/s, done.
Resolving deltas: 100% (374/374), done.
$ cd safe-authenticator-cli/
$ cargo build --features mock-network
thread 'main' panicked at 'assertion failed: prev.is_none()', src/tools/cargo/src/cargo/core/resolver/context.rs:153:25
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace.
Note that I am using latest version of rust:
$ rustc --version
rustc 1.38.0 (625451e37 2019-09-23)
Edit:
Reverting rust version to 1.37.0 makes the compilation works. So, this is a problem brought by latest version of rust.
And now is it supposed to work? I mean new SAFE Browser v0.15.0 with current safe-cli, safe-authenticator-cli and safe_vault built from source. Because I still get the same symptoms.
This sounds like a different issue to me, I’m not able to see safe://test with CLI v.0.4.0 either, are you?
EDIT: I’m sorry @tfa, I’m actually able to fetch it with SAFE CLI v0.4.0 (I had the wrong config before), but so I’m with the browser v0.15.0, aren’t you? perhaps making the same mistake as me not having the correct vault config in place and/or having a local vault running?
I have a local vault and it is the one I want to use. My config file on the PC with safe browser is certainly correct because I get “Connected” and “Accepted” messages with its ip address in the vault logs.
Ah ok, well it also works for me with local vault, uploading a site with CLI v0.4.0 to local vault and loading it with browser v0.15.0 on local vault too. What issue are you experiencing?
Same symptoms as here:
Of course the message in Safe Browser is now: Nobody owns this address yet
Ok, that’s what I just tried, can you please make sure you are re-authorising your CLI before uploading the site to your local vault? if you authorised it before with a safe_auth running against another vault the CLI may be storing the data in a different vault than the one your browser is connecting to.
Normally every thing is properly configured:
On the vault:
  • Existence of safe://test NRS map
$ ./safe cat safe://test
Files of FilesContainer (version 0) at "safe://test":
| Name                    | Size | Created              | Modified             | Link                                                              |
| /img/safe_logo_blue.svg | 5851 | 2019-09-29T19:09:46Z | 2019-09-29T19:09:46Z | safe://hbwynon5ey35si9umca83jkuo6t6qkmkwcp6s9t3g964d9u8fyippaza6z |
| /index.html             | 355  | 2019-09-29T19:09:46Z | 2019-09-29T19:09:46Z | safe://hbhybynoh189jbfes6u1qcu9ojff9rwap9dehr9neop6xikr5atdewactk |
  • Traces of connection from client in vault logs:
$ ./safe_vault --ip pp.pp.pp.pp -p 5483 -vvv > /var/log/safe_vault.log
INFO 2019-09-29T17:39:04Z [src/bin/safe_vault.rs:140] Checking for updates...
INFO 2019-09-29T17:39:05Z [src/bin/safe_vault.rs:169] Current version is 0.19.2
INFO 2019-09-29T17:39:05Z [src/bin/safe_vault.rs:170] No releases are available for updates
INFO 2019-09-29T17:39:05Z [src/bin/safe_vault.rs:119]
Running safe-vault v0.19.2
INFO 2019-09-29T17:39:05Z [src/client_handler.rs:102] QuicP2p started on pp.pp.pp.pp:5483
with certificate [...]
INFO 2019-09-30T19:42:17Z [src/client_handler.rs:153] 3f8f50..: Connected to new client on nn.nn.nn.nn:1024
INFO 2019-09-30T19:42:17Z [src/client_handler.rs:700] 3f8f50..: Accepted App(Bls(85a2ae..), owner: Bls(85a2ae..)) on nn.nn.nn.nn:1024.
INFO 2019-09-30T19:45:21Z [src/client_handler.rs:157] 3f8f50..: Networking error: Connection was actively cancelled
INFO 2019-09-30T19:45:21Z [src/client_handler.rs:159] 3f8f50..: Disconnected from App(Bls(85a2ae..), owner: Bls(85a2ae..)) on nn.nn.nn.nn:1024
(pp.pp.pp.pp is IP address of vault, nn.nn.nn.nn is IP address of client)
  • Config file content (partial):
$ head ~/.config/safe_vault/vault_connection_info.config
  "peer_addr": "pp.pp.pp.pp:5483",
  "peer_cert_der": [
  • Config file checksum:
$ md5sum ~/.config/safe_vault/vault_connection_info.config
c6847c705c782c9971eedfd9cf3ae42c  /root/.config/safe_vault/vault_connection_info.config
On the client:
certutil -hashfile C:\Users\Thierry\AppData\Roaming\MaidSafe\safe_vault\config\vault_connection_info.config MD5
Hachage MD5 de C:\Users\Thierry\AppData\Roaming\MaidSafe\safe_vault\config\vault_connection_info.config :
CertUtil: -hashfile La commande s’est terminée correctement.
  • Navigation attempt to safe://test:
(even though the browser is connected to the vault as shown in vault logs)
There is probably something that I am missing, but what?
Edit:
  • I built both safe-cli and safe-authenticator-cli with cargo build --features mock-network
  • I built safe_vault with cargo build.
Could that be the problem? Should I remove --features mock-network from all build commands?
Exactly, that’s the problem you are facing, you should build both safe_auth and safe_cli for real vault, the local vault is a real vault, and remember to re-authorise the safe CLI with the safe_auth connected to your local vault
Thanks for the info.
But now I get the following error when I try to create an account with safe_auth (on the same machine as the vault):
$ ./safe_auth --test-coins
Secret:
Password:
[2019-10-01T03:29:19Z ERROR safe_auth] safe_auth error: Failed to create an account: AccountContainersCreation("NFS error: NfsError::CoreError -> Request has timed out - CoreError::RequestTimeout")
The corresponding vault log is:
INFO 2019-10-01T03:26:16Z [src/client_handler.rs:153] a8865d..: Connected to new client on pp.pp.pp.pp:443
INFO 2019-10-01T03:26:17Z [src/client_handler.rs:700] a8865d..: Accepted Client(Bls(970930..)) on pp.pp.pp.pp:443.
INFO 2019-10-01T03:26:17Z [src/client_handler.rs:157] a8865d..: Networking error: Connection was actively cancelled
INFO 2019-10-01T03:26:17Z [src/client_handler.rs:159] a8865d..: Disconnected from Client(Bls(970930..)) on pp.pp.pp.pp:443
INFO 2019-10-01T03:26:17Z [src/client_handler.rs:153] a8865d..: Connected to new client on pp.pp.pp.pp:443
INFO 2019-10-01T03:26:18Z [src/client_handler.rs:700] a8865d..: Accepted Client(Bls(970930..)) on pp.pp.pp.pp:443.
INFO 2019-10-01T03:26:18Z [src/client_handler.rs:157] a8865d..: Networking error: Connection was actively cancelled
INFO 2019-10-01T03:26:18Z [src/client_handler.rs:159] a8865d..: Disconnected from Client(Bls(970930..)) on pp.pp.pp.pp:443
INFO 2019-10-01T03:26:18Z [src/client_handler.rs:153] a8865d..: Connected to new client on pp.pp.pp.pp:443
INFO 2019-10-01T03:26:19Z [src/client_handler.rs:700] a8865d..: Accepted Client(Bls(970930..)) on pp.pp.pp.pp:443.
INFO 2019-10-01T03:29:19Z [src/client_handler.rs:157] a8865d..: Networking error: Connection was actively cancelled
INFO 2019-10-01T03:29:19Z [src/client_handler.rs:159] a8865d..: Disconnected from Client(Bls(970930..)) on pp.pp.pp.pp:443
Then I authorized port 443 both udp and tcp, but that didn’t change anything.
I’ve come across that one from time to time (although I didn’t check the vault log). Generally fixed with a reboot.
I’ve just created an account with both secret and password = testing12345. Do you want to see if you can login using those?
Thanks, but I am trying to access my own local vault built from source.
Apart from what @JPL suggested, you can run any of the CLIs with RUST_LOG=trace (or ‘debug’) and see if you get more info
Here are logs from safe_vault and safe-authenticator-cli, but I can’t interpret them:
safe_vault with -vvvv
TRACE 2019-10-01T20:59:24Z [src/chunk_store.rs:94] Creating ChunkStore at /tmp/safe_vault/chunks/login_packets
TRACE 2019-10-01T20:59:24Z [src/utils.rs:26] Creating database at /tmp/safe_vault/immutable_data.db
TRACE 2019-10-01T20:59:24Z [src/utils.rs:26] Creating database at /tmp/safe_vault/full_adults.db
TRACE 2019-10-01T20:59:24Z [src/chunk_store.rs:94] Creating ChunkStore at /tmp/safe_vault/chunks/immutable
TRACE 2019-10-01T20:59:24Z [src/chunk_store.rs:94] Creating ChunkStore at /tmp/safe_vault/chunks/mutable
TRACE 2019-10-01T20:59:24Z [src/chunk_store.rs:94] Creating ChunkStore at /tmp/safe_vault/chunks/append_only
TRACE 2019-10-01T20:59:24Z [src/utils.rs:26] Creating database at /tmp/safe_vault/coins.db
INFO 2019-10-01T20:59:55Z [src/client_handler.rs:153] ad4370..: Connected to new client on 116.203.42.154:443
TRACE 2019-10-01T20:59:55Z [src/vault.rs:222] Node(ad4370..): Succesfully sent message to: 116.203.42.154:443
INFO 2019-10-01T20:59:56Z [src/client_handler.rs:700] ad4370..: Accepted Client(Bls(80e3bc..)) on 116.203.42.154:443.
TRACE 2019-10-01T20:59:56Z [src/client_handler.rs:260] ad4370..: Received (Request::CreateBalance MessageId(6e29ed..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T20:59:56Z [src/client_handler.rs:750] ad4370..: Received (Request::CreateBalance MessageId(6e29ed..)) from src 80e3bc.. (client Client(Bls(80e3bc..)))
TRACE 2019-10-01T20:59:56Z [src/client_handler.rs:1212] ad4370..: Setting balance to 10.000000000 for Bls(80e3bc..)
TRACE 2019-10-01T20:59:56Z [src/client_handler.rs:856] ad4370..: Received (Response::Transaction(Success) MessageId(6e29ed..)) to Client(Bls(80e3bc..)) from ad4370..
TRACE 2019-10-01T20:59:56Z [src/vault.rs:222] Node(ad4370..): Succesfully sent message to: 116.203.42.154:443
INFO 2019-10-01T20:59:56Z [src/client_handler.rs:157] ad4370..: Networking error: Connection was actively cancelled
INFO 2019-10-01T20:59:56Z [src/client_handler.rs:159] ad4370..: Disconnected from Client(Bls(80e3bc..)) on 116.203.42.154:443
INFO 2019-10-01T20:59:57Z [src/client_handler.rs:153] ad4370..: Connected to new client on 116.203.42.154:443
TRACE 2019-10-01T20:59:57Z [src/vault.rs:222] Node(ad4370..): Succesfully sent message to: 116.203.42.154:443
INFO 2019-10-01T20:59:57Z [src/client_handler.rs:700] ad4370..: Accepted Client(Bls(80e3bc..)) on 116.203.42.154:443.
TRACE 2019-10-01T20:59:57Z [src/client_handler.rs:260] ad4370..: Received (Request::CreateLoginPacket MessageId(baa831..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T20:59:58Z [src/client_handler.rs:1237] ad4370..: Client(Bls(80e3bc..)) is paying 0.000000001 coins
TRACE 2019-10-01T20:59:58Z [src/client_handler.rs:1212] ad4370..: Setting balance to 9.999999999 for Bls(80e3bc..)
TRACE 2019-10-01T20:59:58Z [src/client_handler.rs:750] ad4370..: Received (Request::CreateLoginPacket MessageId(baa831..)) from src 80e3bc.. (client Client(Bls(80e3bc..)))
TRACE 2019-10-01T20:59:58Z [src/client_handler.rs:856] ad4370..: Received (Response::Mutation(Success) MessageId(baa831..)) to Client(Bls(80e3bc..)) from c77dec..
TRACE 2019-10-01T20:59:58Z [src/vault.rs:222] Node(ad4370..): Succesfully sent message to: 116.203.42.154:443
INFO 2019-10-01T20:59:58Z [src/client_handler.rs:157] ad4370..: Networking error: Connection was actively cancelled
INFO 2019-10-01T20:59:58Z [src/client_handler.rs:159] ad4370..: Disconnected from Client(Bls(80e3bc..)) on 116.203.42.154:443
INFO 2019-10-01T20:59:58Z [src/client_handler.rs:153] ad4370..: Connected to new client on 116.203.42.154:443
INFO 2019-10-01T20:59:58Z [src/client_handler.rs:700] ad4370..: Accepted Client(Bls(80e3bc..)) on 116.203.42.154:443.
TRACE 2019-10-01T20:59:58Z [src/client_handler.rs:260] ad4370..: Received (Request::GetMDataValue MessageId(040f78..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T20:59:59Z [src/data_handler.rs:86] ad4370..: Received (Request::GetMDataValue MessageId(040f78..)) from src 80e3bc.. (client Client(Bls(80e3bc..)))
TRACE 2019-10-01T20:59:59Z [src/client_handler.rs:856] ad4370..: Received (Response::GetMDataValue(NoSuchData) MessageId(040f78..)) to Client(Bls(80e3bc..)) from 06a33b..
TRACE 2019-10-01T20:59:59Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(e5739c..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T20:59:59Z [src/vault.rs:222] Node(ad4370..): Succesfully sent message to: 116.203.42.154:443
TRACE 2019-10-01T20:59:59Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(447f8d..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T20:59:59Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(130c77..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:00Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(414ee2..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:00Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(96a86f..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:00Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(f183de..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:01Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(54ee91..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:01Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(89c8a0..)) from Client(Bls(80e3bc..))
TRACE 2019-10-01T21:00:01Z [src/client_handler.rs:260] ad4370..: Received (Request::PutMData MessageId(5a577e..)) from Client(Bls(80e3bc..))
INFO 2019-10-01T21:02:58Z [src/client_handler.rs:157] ad4370..: Networking error: Connection was actively cancelled
INFO 2019-10-01T21:02:58Z [src/client_handler.rs:159] ad4370..: Disconnected from Client(Bls(80e3bc..)) on 116.203.42.154:443
safe_auth with RUST_LOG=trace (only lines containing safe_core)
[2019-10-01T20:59:55Z TRACE safe_core::client] Create test balance of 10.000000000 for SecretKey("...")
[2019-10-01T20:59:55Z TRACE safe_core::config_handler] Not available: /root/.config/safe_core/safe_core.config
[2019-10-01T20:59:55Z TRACE safe_core::config_handler] Reading: /root/.config/safe_vault/vault_connection_info.config
[2019-10-01T20:59:55Z TRACE safe_core::connection_manager] Trying to bootstrap with group Client(Bls(80e3bc..))
[2019-10-01T20:59:55Z TRACE safe_core::connection_manager::connection_group] 0: Bootstrapped
[2019-10-01T20:59:55Z TRACE safe_core::connection_manager::connection_group] 0: Message from V4(116.203.42.154:5483): [ 00 00 00 00..e8 0f 47 2c ]. Have we handled challenge? false
[2019-10-01T20:59:55Z TRACE safe_core::connection_manager::connection_group] Got the challenge
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Sent user message
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(6e29ed..)
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Message from V4(116.203.42.154:5483): [ 02 00 00 00..02 00 00 00 ]. Have we handled challenge? true
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] Got transaction notification: Notification(Transaction { id: 3541782569029540645, amount: 10.000000000 })
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Message from V4(116.203.42.154:5483): [ 01 00 00 00..87 89 93 7a ]. Have we handled challenge? true
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Response from: V4(116.203.42.154:5483), msg_id: MessageId(6e29ed..), resp: Response::Transaction(Success)
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager] Disconnecting group Client(Bls(80e3bc..))
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Terminating connection
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager::connection_group] 0: Successfully disconnected
[2019-10-01T20:59:56Z TRACE safe_core::connection_manager] Dropped ConnectionManager - terminating gracefully
[2019-10-01T20:59:57Z TRACE safe_core::config_handler] Not available: /root/.config/safe_core/safe_core.config
[2019-10-01T20:59:57Z TRACE safe_core::config_handler] Reading: /root/.config/safe_vault/vault_connection_info.config
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager] Trying to bootstrap with group Client(Bls(80e3bc..))
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager::connection_group] 1: Bootstrapped
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager::connection_group] 1: Message from V4(116.203.42.154:5483): [ 00 00 00 00..b2 9b d9 a2 ]. Have we handled challenge? false
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager::connection_group] Got the challenge
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager::connection_group] 1: Sent user message
[2019-10-01T20:59:57Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(baa831..)
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 1: Message from V4(116.203.42.154:5483): [ 01 00 00 00..6d 5e 09 19 ]. Have we handled challenge? true
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 1: Response from: V4(116.203.42.154:5483), msg_id: MessageId(baa831..), resp: Response::Mutation(Success)
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager] Disconnecting group Client(Bls(80e3bc..))
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 1: Terminating connection
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 1: Successfully disconnected
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager] Trying to bootstrap with group Client(Bls(80e3bc..))
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 2: Bootstrapped
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 2: Message from V4(116.203.42.154:5483): [ 00 00 00 00..02 dc 2b 65 ]. Have we handled challenge? false
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] Got the challenge
[2019-10-01T20:59:58Z TRACE safe_core::client] Fetch MDataValue for 06a33b..
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] 2: Sent user message
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(040f78..)
[2019-10-01T20:59:58Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: d39403.., tag: 15000 }, enc_info: Some((Key(****), Nonce([96, 130, 124, 152, 40, 1, 206, 203, 127, 230, 91, 112, 197, 127, 155, 174, 0, 237, 132, 252, 1, 116, 140, 38]))), new_enc_info: None }
[2019-10-01T20:59:58Z TRACE safe_core::client] Put Sequenced MData at d39403..
[2019-10-01T20:59:58Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(e5739c..)
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] 2: Message from V4(116.203.42.154:5483): [ 01 00 00 00..af e1 ce 47 ]. Have we handled challenge? true
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] 2: Response from: V4(116.203.42.154:5483), msg_id: MessageId(040f78..), resp: Response::GetMDataValue(NoSuchData)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 389259.., tag: 15000 }, enc_info: Some((Key(****), Nonce([176, 228, 7, 168, 138, 6, 37, 118, 204, 247, 5, 213, 56, 90, 24, 49, 76, 81, 242, 146, 245, 192, 225, 198]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 389259..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(447f8d..)
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] 2: Sent user message
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 32fa09.., tag: 15000 }, enc_info: Some((Key(****), Nonce([162, 59, 12, 225, 29, 228, 194, 59, 152, 134, 100, 37, 211, 116, 173, 208, 35, 28, 98, 236, 43, 140, 221, 95]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 32fa09..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(130c77..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 777f2c.., tag: 15000 }, enc_info: Some((Key(****), Nonce([147, 207, 221, 165, 101, 133, 31, 248, 224, 87, 212, 99, 69, 190, 68, 128, 17, 99, 170, 54, 126, 155, 152, 87]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 777f2c..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(414ee2..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 8f2ca9.., tag: 15000 }, enc_info: None, new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 8f2ca9..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(96a86f..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: b00e71.., tag: 15000 }, enc_info: Some((Key(****), Nonce([7, 119, 158, 185, 253, 38, 185, 181, 48, 71, 84, 62, 35, 172, 193, 146, 239, 17, 70, 221, 51, 226, 182, 220]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at b00e71..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(f183de..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 8c1ab5.., tag: 15000 }, enc_info: Some((Key(****), Nonce([62, 138, 206, 227, 27, 202, 117, 38, 204, 17, 193, 200, 130, 206, 11, 156, 212, 135, 240, 117, 155, 89, 54, 208]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 8c1ab5..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(54ee91..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 6abcd6.., tag: 15000 }, enc_info: Some((Key(****), Nonce([244, 123, 246, 234, 3, 217, 151, 94, 227, 127, 7, 85, 138, 165, 120, 14, 200, 60, 63, 123, 126, 213, 79, 42]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 6abcd6..
[2019-10-01T20:59:59Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(89c8a0..)
[2019-10-01T20:59:59Z TRACE safe_core::nfs::dir] Creating new directory: MDataInfo { address: Seq { name: 06a33b.., tag: 15000 }, enc_info: Some((Key(****), Nonce([230, 239, 231, 5, 31, 175, 24, 210, 141, 236, 87, 246, 189, 227, 192, 105, 184, 124, 102, 119, 153, 218, 166, 192]))), new_enc_info: None }
[2019-10-01T20:59:59Z TRACE safe_core::client] Put Sequenced MData at 06a33b..
[2019-10-01T21:00:00Z TRACE safe_core::connection_manager::connection_group] Sending message MessageId(5a577e..)
[2019-10-01T21:00:00Z TRACE safe_core::connection_manager::connection_group] 2: Sent user message
[2019-10-01T21:02:58Z TRACE safe_core::nfs::dir] Error: Request has timed out - CoreError::RequestTimeout
[2019-10-01T21:02:58Z DEBUG safe_core::event_loop] Exiting Core Event Loop
[2019-10-01T21:02:58Z TRACE safe_core::connection_manager] Dropped ConnectionManager - terminating gracefully
[2019-10-01T21:02:58Z TRACE safe_core::connection_manager::connection_group] Gracefully terminating quic-p2p event loop
I don’t see anything that could explain it, it seems like safe_auth is sending several messages to create a MD, that’s not what I see in my local instances when creating an account. Are you experiencing this also with safe_auth and safe_vault downloaded from the GH releases? do you still see that time out error in the console?
I have done tests with all possible combinations of binaries downloaded from github or rebuilt from source. The results are the following:
  • rebuild auth + rebuild vault => NOK
  • binary auth + rebuild vault => NOK
  • binary auth + binary vault => OK
  • rebuild auth + binary vault => OK
This means that my configuration is correct because I got some successful cases, but the problem is rebuilding vault from source.
Then I discovered that there is a phase1 branch in safe_vault repo, so I tried compiling this branch instead of master. But unfortunately the generated exe doesn’t work too.
The conclusion is that I am unable to build a vault from source that works with authenticator.
And this was only a preliminary step because I would like the vault to be compatible also with safe_cli rebuilt from source and with SAFE Browser V0.15.0 (Pweb).
I’m not aware of the details in vault development so I’m not sure if the code in master is still backward compatible with v0.19.2, from your analysis/test it seems it’s probably not, so you could try building from source using tag https://github.com/maidsafe/safe_vault/tree/0.19.2, but I’m not sure what you are trying to achieve as that would give you just the same binary/functionality as the one you download from github releases
This tag is the same as phase1 branch (with latest commit 61c20dd). I just want to be able to build a vault from source so that I can modify it (for example getting statistics).
I just tried building and running safe_vault from tag 0.19.2 just with cargo build and I’m able to login with safe_auth v0.3.0
