Read back my comment which you quoted before saying this. I said you will have LOTS of connections - you’re not telling me anything I don’t know. I’m not sure what it is but people either aren’t understanding what I’m saying or they’re not listening.
You’ve just contradicted yourself and are now saying that they will see more than this. They will see that you are transferring data between all other connected nodes…not just 2 streams of data (up and down)!!!
Taking the Torrent example. If your client decides to download chunks of 1MB from each connected peer then I can tell how long you’ve been connected to this other client. If I was an ISP with details of the other peer then I could also tell what connections they had open during that time…so if I was streaming data where the other client was acting as a relay I would have a reasonably good idea what inbound connection to them was feeding through to the outbound connection to me because they would likely live for pretty much the same amount of time. This is the most basic way of gauging this. As I’ve said there will likely be other pattern that could be used to.
You’ve already proved it. The part of Breaking Bad didn’t magically appear on your computer and you can demonstrate through logs that the data that came from them, which was then decrypted became a part of breaking bad. What you are saying is similar to a thief thinking that they can steal a sandwich from a shop, get recorded on CCTV in the process but they’ll be OK because the ate the sandwich. I’m not saying the person who’s running the node is a thief, what I’m saying is that there’s a recording of what happened so the data doesn’t need to exist on their system any more.
There’s nothing magical about it. When you connect to the Maidsafe servers you are not connecting directly to them. When you connect to ANYTHING over the Internet you are first going to go through your ISP. They are in complete control of where you’re routed - I don’t know what ISP you’re with but it’s not uncommon for them to block access to certain websites…I don’t understand why people aren’t getting this.
Forgive me for not aknowledging more of your points Tonda but I think I’d be close to repeating what I’ve already said in this post.
I’m not so sure about this comment. You are obviously security conscious however I’d say you are in the minority. If SAFE starts attracting Mr Average I’d bet money that most won’t update frequently (unless forced). I’ve been on plenty of servers owned by massive businesses and found them running outdated versions of nearly everything.
The security issues involved with running outdated software are obviously not new. Microsoft are taking a slightly different approach these days but not that long ago they were letting (encouraging) people they KNEW were running pirate copies of Windows to keep Windows update running. It was recognised that hookie unpatched copies were a security risk to their legitimate customers.
