Would something like this be usefull for every Dev Update?
I think I might need squared stickers
Iâve created an A4-sheet for printing on sticker paper. Iâll do this for every update and upload it to the dropbox folder
why so many errors and untreated Java ExceptionsâŚ
the testnet and Alpfa2 should of been up and running by now.
Also not to mention the replacement of Maid with Safecoin.
I donât find anywhere written of how the consensum of the SafeCoin will be done. Is POS ? who will validate your transaction?
What are you meaning. Alpha 2 has been running for a while now.
in your roadMap you didnât pass Alpha2.
And another thingâŚwhat is with this browser developmentâŚ
Previously I could connect to Maid test network with Firefox on a given proxyâŚand now I have to use a special browser
Which means we are at alpha 2 now. If we were past it then alpha 2 would be finished and we would be near alpha 3 wouldnât we.
Correct.
Firefox does not provide the security. SAFE is about the user being able to be in control of their data and not leaking their data to others. All the current browsers due to accessing the current web leak your data everywhere, from DNS access (what sites you visit) to tracking info to giving facebook, google, twitter info on the sites you visit because the sites have those share images on them.
okâŚbut still this is not a good approach since SafeNet should be used with every browser and not with only 1 browser.
SecondâŚsince you admitted you didnât pass Alpha 2âŚyou didnât answer to my questionâŚwhen is it going to be finished and what kind of a consensum Safe coin has
When its finished and not before.
In other words it will run till it is shut down because alpha3 is ready to be run up.
If you read the updates then you will know as much as I do.
Did you mean consensus?
Safecoin is handled by the network itself when its implemented during the beta releases. Test coin first.
Network consensus is the basis of safecoin consensus since the coin are individual data objects stored on the network, and so the consensus that occurs within sections also protects safecoin.
It might help to read the primer on the SAFE network. The SAFE Network Primer: An Introduction to the SAFE Network
PS. Safenet is owned by another company not associated with crypto. We are now calling the network either SAFE or SAFE network
Please note that I didnât answer
because the question you asked was
So I answered why alpha 2 was not up and running since you obviously thought it had not started yet
