Determined to finally download this file this time around
BOOOOOOOOM! Amazing!!
I wasn’t explicit about this, but my first question was about relocated adults that stay adults.
This implies that adults don’t need to allow any port. But relocations won’t work if the problems I mentioned are not corrected. Hence my first question.
My second question was about your own nodes. Do you allow the port used by each of your nodes?
the download works this time
takes about one minute
That’s amazing. 8 minute song with zero speed optimisations yet. This is looking increasingly real
just uploaded a folder with 29 files totaling 17.9MiB, took about 15 minutes, in v4 I didn’t even get that far
Does the second attempt run faster than the origional attempt?
Great work guys. Will test after work.
Whats the risk of downloading a malicious file from someone on a test. Not saying anyone here would but as more people join the tests is this something to be cautious of. ie use a different computer?
For pictures and music I think risk is minimal.
no same time! about 1-2 minutes
if I join as a node how much storage space is required for a node?
Anecdotally, last night I was seeing repeated attempts to put already existing files to the local baby-fleming seemed to take longer each time - although the chunks already existed in the vaults.
It depends on how long this network will function without glitches.
My node never got even 1 GB.
So I think ~10 GB or higher should be enough.
It will automatically set your storage size as something like 85% of you available free disk space. So for now you dont need to worry about. For now
I see network slowdown now.
Can anyone test if it is working as fast as ~10 min before?
upd. There was a lag of ~10 minutes duration.
Now network responds again.
We may start to hit OOM problem.
upd2. Lagging and working periods are changing each other.
FilesContainer created at: “safe://hyryyrbcjutzu1xauruboc3knodfqg8qxqcu865mqk5cbtjsrnfu6x9otfynra”
- En Lefko Nu Funk Nu Soul.mpeg safe://hy8aynyxetwgzf3uoimjdpoqh3jzd7he6db1torsa5br6dw7f1sy15nnx3o
some nu funk / nu soul 30mb~
I’ve got it ! 70,8 MB Yeaaaah
Took a few minutes on 4G
reuploading the nu funk nu soul it is uploading, maybe deduplication should work locally just checking hashes or something?
safe://hy8ayqyqz7iwuhq68csyobfrqmrg75nbopopjk4w8n3a718tt54nsoywkse > sintel.mp4
this is a 129.2MB video it took me 1m.56s to download, pretty fast!
