By the way, when my node was elder in previous testnet, it was using ~800MB of RAM.
Which looks like more than all network data at that moment.
What is stored there and why it is so large?
Yes true, I understand. Unless the bug is because AE isnât there ![]()
Theoretically it should be possible to prove if this hypothesis is true or false.
Nodes are writing log files for reason.
upd. Hmm⌠it may be that our discussion makes little sense )
Damn, they are quick! ![]()
Adults connect to Elders in the same way clients do. If we cannot connect back to them they are not allowed to promote to Elder.
This is the same thing as above. If a node cannot be contacted it cannot promote.
If you run a node that could be contacted and donât allow it then it will not become an Elder. If that means opening a port etc. then itâs best you run a node with the port open.
Looks like they went with your suggestion!
yahoo⌠this is good to see ![]()
No thatâs us pushing T6 while debugging T5 is happening
But you never know these days ![]()
Update from MaidSafe HQ
We are now back online! Testing can start again.
Please remember to follow the full instructions, you need to remove your ~/.safe/ dir and re-add the network configuration.
We will be monitoring for the OOM issue happening again.
much better now,
congrats to @bochaco btw ! ![]()
$ safe keys create --test-coins --for-cli
New SafeKey created: âsafe://hyryyyy8rbidrqyq69apf6mgoipp95fikbau3mccqcd96a6uaww891c9graâ
Preloaded with 1000.111 testcoins
Key pair generated:
Public Key = e40d464701defe1a5f2cd0ab5bfd96aa0e2795b18e60ffec7a78a50ff933e626
Secret Key = 8e66d859516a3780c33f09d3aea41c6b846ba2f564b614a7111f4cd9f35a2181
Setting new SafeKey to be used by CLIâŚ
New credentials were successfully stored in C:\Users\colmo.safe\cli\credentials
Safe CLI now has write access to the network
YES!
Omg⌠running.
Looks like upload now works faster. Strange. Nothing should be changedâŚ
im in happy days well done to all the team for quick turn around on 5.1 !
We are suspecting a long running mem leak will be found. Meanwhile Ae progresses and might answer the bug in any case.
the OOM bug wont show cause it knows weâre looking for it⌠![]()
Then we test other features ))
I mean enabled memory profiling should not make upload faster.
But I clearly see difference.
Yes I suspect we are seeing nodes not currently being hampered by OOM issues, but they likely will.
So nodes begin to swap because of low RAM condition which makes upload slower? Look plausible.
