Tried safe node join and I get [sn_node] ERROR 2021-04-22T17:40:35.355171+02:00 [src\bin\sn_node.rs:125] Cannot start node due to error: Logic("Config error: Invalid Ed25519 public key bytes"). If this is the first node on the network pass the local address to be used using --first. Exiting
Nice, thanks.
For me it hanging on
[sn_client::connection_manager] WARN 2021-04-22T18:38:11.360275600 [C:\Users\run neradmin\.cargo\registry\src\github.com-1ecc6299db9ec823\sn_client-0.52.16\src\c onnection_manager.rs:708] No matching pending query found for elder 138.68.143.1 91:45341 and message MessageId(bb625d(10111011)..)
Since small file works, maybe large one will work too? (68 MB)
safe cat safe://hyryyyymmy7wefy4qn5fjiuea4wwkdbg5j8ibxqiqmi8hi5bij4pte56ppa > 1.flac
Got it too! Nice big pic ![]()
Downloaded for me really quickly ![]()
@oetyng you are a beast but a kind one! Maidsafe got a nitro boost after your joining and I know itâs not a coincidence. Thank you to you personally and to all @maidsafe! Congrats on v4! ![]()
Ps Iâm SUPER excited about DBC work!
This would be AMAZING THANK YOU!!!
some sounds for you to try downloadingâŚ
willie@gagarin:~/Music$ safe files put -r 01.\ The\ Rolling\ Stones\ \ -\ 1964/
FilesContainer created at: âsafe://hyryyry4ufwiw66899h9cf58zt6d783buaa6wyubnit75i9zfcj76kjzuocnraâ
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 02 - Route 66.mp3 safe://hygyy1yxf8fso597tk8b1fs1s8rimj37uaehxgufuqxq3txesde5e6urror
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 04 - Honest I Do.mp3 safe://hygyy1ymj8114pyosouayyi5k5usdx6dwp8zjdg4mpkjihncgcfec9iphxr
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 06 - Little by Little.mp3 safe://hygyy1yj9yg9eg9gjjiz1wanyb77ej88gi4hkn5m67qb43t9xrogrkk98sw
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 08 - Carol.mp3 safe://hygyy1ypoczs8c33skw3jmg1efsjsexmdxosgmhsbrhno1jiobhjm9ets6c
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 09 - Tell Me.mp3 safe://hygyy1yc1em3z7oo3dmyn9psjsn3nrzzayuw7yxy1ffojy6nzrid9tibjaa
- The Rolling Stones - 1964/Rolling Stones - The Rolling Stones (Englandâs Newest Hitmakers) - 12 - Walking the Dog.mp3 safe://hygyy1yxr9xxmm77nmc3qa477ck6k87hgeni6ayxt3aso6bhbqay3mzqu1w
- The Rolling Stones - 1964/Rolling_Stones_-_Englands_Newest_Hitmakers_Abkco-back[1].jpg safe://hygoygymwfbmxp85a6xjwe7dm37g8cs58qnwfrxmy8x1jssiq485g9mm7po
- The Rolling Stones - 1964/Rolling_Stones_-_Englands_Newest_Hitmakers_Abkco-front[1].jpg safe://hygoygyxmtwdgj6qgyqmbmybmu7cx9cdtqxb6an1qo15ry44ynntdos3zqa
- The Rolling Stones - 1964/Rolling_Stones_-_Englands_Newest_Hitmakers_Abkco-inside[1].jpg safe://hygoygycy3oyqnwutjxfowfdqhdhgehnfh1bewjirq58dirnt4mz373hcrh
- The Rolling Stones - 1964/Tracks and Notes.txt safe://hy8oycymzuqcttgtfaxymmho59jgp59t6u58rddgbadnamastrhesk6wpfh
Iâm getting about 1.9 MiB/s on these bigger files, which is saturating my rather poor connection (full fibre is coming up my road⌠slowly!). It seems to take a while for some of them to start downloading in earnest, but then it is pretty constant.
Thatâs because you didnât remove an old $HOME/.safe/ folder, make sure you clean it before trying to join, at least remove $HOME/.safe/node/local-node folder and try the join command again.
Surely rm -rf $HOME/.safe and nuke the lot? - Download it ALL fresh #WorksForMe
Thank you it is working now. If I try safe keys create --test-coins --for-cli its still hanging.
Give it some time, it can be slow, it is for me that command too. Make sure you switch to the network though, so it pulls updated connection information for new testnet.
Thank you very much, will do that ![]()
$ safe cat safe://hyryyyymmy7wefy4qn5fjiuea4wwkdbg5j8ibxqiqmi8hi5bij4pte56ppa > 1.flac
Error: NetDataError: Failed to GET Public Blob: SelfEncryption(Storage)
I think this was the one maxing my connection, but then I got this:
paul@Vader:~/tmp$ safe cat safe://hyryyyymmy7wefy4qn5fjiuea4wwkdbg5j8ibxqiqmi8hi5bij4pte56ppa > 1.flac
[sn_client::connection_manager] ERROR 2021-04-22T16:53:05.482732315 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:05.940052522 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:06.792607148 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: TargetSectionInfoOutdated(SectionInfo { prefix: Prefix(00), pk_set: PkSet { public_key: PublicKey(0d9c..be3e) }, elders: {0a8421(00001010)..: 159.65.16.192:41964, 14d58c(00010100)..: 138.68.167.96:57364, 1afee6(00011010)..: 138.68.129.95:12000, 1b1087(00011011)..: 138.68.143.191:45341, 25cb61(00100101)..: 159.65.31.25:35763, 26f885(00100110)..: 138.68.150.83:47689, 373040(00110111)..: 159.65.31.154:39678}, joins_allowed: false}) }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:07.358069358 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:08.013006549 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:08.038542897 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
[sn_client::connection_manager] ERROR 2021-04-22T16:53:09.339364493 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.16/src/connection_manager.rs:609] MessageId MessageId(8d42ad(10001101)..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(8d42ad(10001101)..), error: DkgInProgress }
It is still running, but it may have hung.
Looks like the section may have split during download?
Amazing speed team!
I get tis error:
safe networks switch fleming-testnet
Switching to âfleming-testnetâ networkâŚ
Fetching âfleming-testnetâ network connection information from âhttps://sn-node.s3.eu-west-2.amazonaws.com/config/node_connectionâ âŚ
Error: Format of the contacts addresses is not valid and couldnât be parsed
Caused by:
expected value at line 1 column 1
Iâm on Linux Budgie
Switch to the network? You mean this command safe networks switch fleming-testnet?
