OK, then I’ll just let the node behave well.
Hmm… I got the file, but it is empty. Trried three times, logs below.
Summary
topi@topi-HP-ProBook-450-G5:~$ safe files get safe://hyryyry6eb75j19xmfbaaff393qn1komwu84ku5e77sqhupdrdidyzybddrnra
File [1 of 1]: freedom.jfif
⠁ [00:00:01] [----------------------------------------] 0B/10.24KB (0B/s, 0s) Transfer
Done. Retrieved 1 files to .
topi@topi-HP-ProBook-450-G5:~ safe files get safe://hyryyry6eb75j19xmfbaaff393qn1komwu84ku5e77sqhupdrdidyzybddrnra
overwrite './freedom.jfif'? [Y/n]: Y
⠁ [00:00:07] [----------------------------------------] 0B/10.24KB (0B/s, 0s) Transfer
Done. Retrieved 1 file to ..
pre-existing: 1 (overwritten: 1 preserved: 0)
So, I haven’t much time this evening to pay attention or read thread here to wonder but I’m dumping simple upload commands to terminal and coming back to see a run of errors all look like this one:
[sn_client::connection_manager] ERROR 2021-04-13T20:16:32.493550426 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.10/src/connection_manager.rs:609] MessageId MessageId(035c22..) was interrupted due to infrastructure updates. This will most likely need to be sent again. Update was : ErrorResponse { correlation_id: MessageId(035c22..), error: DkgInProgress }
? what are infrastructure updates and who is runner /home/runner/.cargo is not a user on this system.
Not sure about that one. Could it be the file type? Image was viewable for me.
I got chunks woohoo. Took about 1 hour 30 miunutes.
Ok @HTPeacock, thanks for trying again, something not right there.
If you get a chance would you be able to send over the output of $ safe auth status and your sn_authd.log output from ~/.safe/authd/logs/sn_authd.log? Thanks in advance
Well that was exciting! I’ve never cross compiled before… ever!
I just blindly bashed on my keyboard…
- On my raspberry pi ran the original install script in the first post of this v2 update.
… just to get all the shortcuts in place… - Cross compiled (musl) safe, safe cli and safe node, on a digital ocean ubuntu droplet.
- Replaced these in my local pi install.
I now have an IT Crowd “internet in a box” running here…
going to play with downloading and uploading files now.
Raspberry Pi 4 EVR !!!
I’m running raspberry pi OS 64bit aarch64 on an 8GB pi4, booted with berryboot.
The case is a GeeekPi Argon Case with m.2 ssd expansion slot which currently has 500GB waiting
to be eaten up by the test net.
Just to keep all the pi in the same post
I’m maybe too excited.
This is when doing $safe auth status
Sending request to authd to obtain a status report...
Error: AuthdClientError: [Error] ClientError - Response not received: read error: connection closed: timed out
Log:
WARN 2021-04-13T20:56:29.139079+02:00 [/Users/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/qp2p-0.11.8/src/connections.rs:260]
Failed to read incoming message on bi-stream for peer 46.101.82.188:37364 with error: the endpoint encountered an internal error and cannot continue with the connection: endpoint driver future was dropped
Thanks for the help @StephenC
I also get a lot of timeouts when trying to unlock the Safe. After a lot of attempts it worked.
Also uploading a file has worked once for me, most of the time it hangs
What is the command to upload a file?
safe files put ./to-upload/myfile.txt
Churn is happening.
I am not sure what you are asking here.
PROBLEM: Similar to Toivo, though my Ubuntu cloud node ran for at least a couple of hours before the log stopped adding join attempt messages. The process was still running. Here’s the end of the log:
$ tail ~/.safe/node/local-node/sn_node.log
[sn_node] INFO 2021-04-13T20:58:31.271055314+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:02:02.536820578+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:05:12.766192255+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:08:23.025753116+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:11:33.276698556+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:15:13.503593552+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:18:23.830590183+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:21:47.482159309+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:25:27.784004603+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
[sn_node] INFO 2021-04-13T21:29:07.035414443+02:00 [src/bin/sn_node.rs:118] "The network is not accepting nodes right now. Retrying after 3 minutes"
I’ve now done safe node killall and safe node join and letting it run again.
It’s in the error message as /home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.10/src/connection_manager.rs:609
Not sure I’ve seen that before.
If churn is happening does the request to upload need reissuing?
Im having a lot of issues with hanging on safe commands now. Was much faster earlier.
Just got this error too.
safe keys create --test-coins --preload 15.342
[sn_client::connection_manager] ERROR 2021-04-13T12:58:34.675977832 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.10/src/connection_manager.rs:927] Error handling network info message: InsufficientElderConnections(4)
parallels@parallels-Parallels-Virtual-Platform:~$ safe files put .‘/home/parallels/a2723954457_10.jpg’
[sn_client::connection_manager] ERROR 2021-04-13T13:06:13.111105498 [/home/runner/.cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.10/src/connection_manager.rs:927] Error handling network info message: InsufficientElderConnections(4)
Ubuntu 20.04 fully updated
The /home/runner is a dir on your machine.
The .cargo/registry/src/github.com-1ecc6299db9ec823/sn_client-0.52.10/src/connection_manager.rs:609
Is the file and location of the error AFAIK
Yes but that’s the oddity… there is no /home/runner dir on my machine… I guess it might be source of the code?.. but odd it’s declared at all.
Today I have the feeling that section with prefix 0 is a black hole because I cannot connect any client with a public key beginning with 0, 1, … 7.
Section with prefix 1 can be connected with no problems (clients beginning with 8, 9, …f).
Can someone confirm this?
I saw a similar message yesterday, “/home/runner” , I found it curious, then forgot about it.
