above suggested yes - could do with suggested halted or node stopped in the log to make this more obvious.
Could you provide a link to the user guide?
Thanks. First time I had UPnP turned off, and assumed the error was due to that. Then turned it on and got same error, so I read the info in the OP. That is why I questioned it.
And thanks for letting me know its a one attempt at joining. That shell loop is something I was thinking of doing. Although I was thinking of a while loop. Until is prob better.
sascha@sascha-Librem-15-v3:~$ until grep -q "Handling NodeDuty" ~/.safe/node/local-node/sn_node.log; do safe node join; sleep 30; done
Joining network with contacts {138.68.154.164:44520, 138.68.142.76:38701, 46.101.1.135:58214, 188.166.146.65:36220, 138.68.139.28:40613, 138.68.142.144:55064, 138.68.141.132:36390, 46.101.48.69:55130, 138.68.146.110:58306, 138.68.152.156:51182, 188.166.146.115:41339, 138.68.139.58:38972, 46.101.55.62:53141, 46.101.78.184:41244, 138.68.131.228:40591, 138.68.139.187:33546, 138.68.138.179:51519, 138.68.138.75:59177, 138.68.131.119:50694, 139.59.181.74:12000, 178.62.80.163:57378, 138.68.154.35:49429, 46.101.17.63:38981, 188.166.169.192:47334, 138.68.137.76:34625, 178.62.101.46:59428, 138.68.137.198:43750, 138.68.133.17:37599, 138.68.146.15:34651, 178.62.58.241:42766, 46.101.72.229:52737, 46.101.93.86:56133, 138.68.131.218:57691} ...
Storing nodes' generated data at /home/sascha/.safe/node/local-node
Launching with node executable from: /home/sascha/.safe/node/sn_node
Version: sn_node 0.35.1
Using RUST_LOG 'sn_node=debug'
Node to be started with contact(s): ["138.68.154.164:44520","138.68.142.76:38701","46.101.1.135:58214","188.166.146.65:36220","138.68.139.28:40613","138.68.142.144:55064","138.68.141.132:36390","46.101.48.69:55130","138.68.146.110:58306","138.68.152.156:51182","188.166.146.115:41339","138.68.139.58:38972","46.101.55.62:53141","46.101.78.184:41244","138.68.131.228:40591","138.68.139.187:33546","138.68.138.179:51519","138.68.138.75:59177","138.68.131.119:50694","139.59.181.74:12000","178.62.80.163:57378","138.68.154.35:49429","46.101.17.63:38981","188.166.169.192:47334","138.68.137.76:34625","178.62.101.46:59428","138.68.137.198:43750","138.68.133.17:37599","138.68.146.15:34651","178.62.58.241:42766","46.101.72.229:52737","46.101.93.86:56133","138.68.131.218:57691"]
Launching node...
Node logs are being stored at: /home/sascha/.safe/node/local-node/sn_node.log
I have been silently watching this project for a few years now, but I want to say well done all. This is very exciting and I will have a go at setting up a node at the weekend. Rather exciting to watch ![]()
Do you mean port forwarding here? (i.e. nodes need incoming connections to be able to work, otherwise they will fail)
Yes, this is a wee bit dangerous really. It allows traffic snoopers to find Safe nodes a bit easier, if they are random then it helps us hide a wee bit more. This one may also suffer linger and port reuse issues in the OS.
5483 though was a fallback, find me port, not really meant for general use, but used as a way to reconnect nodes on total loss? (i.e. fine any of these ports on a network to try connector as Safe nodes). 5483 was LIVE in the telephone keypad (it was my joke for the network wants to live
That requirement won’t exist in next iter. Nodes will join a queue, stay connected and be selected at random (based on the hash of the lost or full node message, so ungamable)
I agree, the difference being the test net has yet to fully crash, in fact, it is still flying. This was never a speed test, it was a test to see whether it would fly. Its flying, It worked. Its stable. It will fly higher soon, much higher. The hard part is over, the team has given it wings.
Yes, we need to test it, be critical, try hard to break it, and I thank the community for that, but let us rejoice for now! It worked!
Also I found the easiest way to join the test-net was to download the CLI binary from github, for those having issues with terminal on MAC OS, cheers. Great work team!
No, I really meant open a port in firewall, for example ufw allow 5483/udp with ufw.
for example
ufw allow 5483/udp
Oh I see in your local firewall on your local computer? That makes more sense and yea a valid use case I would say.
I’ll go right out there and say that starting an account and writing data to the network and transferring tokens on my first try is a huge win. The software just works (as far as setup), and that is not a small feat for a distributed network.
This requires storage of the queue, and updating it if nodes go away, and handling if it gets too big. Might it be prone to spamming in order you get more nodes in the queue that someone else? I guess repeated join requests (with no queue) are also open to this kind of attack.
A way to limit this effect might be to have more do some work for each join attempt, but that work needs to be something that can’t be done faster with more CPU, maybe something more like you have to route N messages before you get to join.
I guess you’ve been around these houses a few times already, but I’m not saying how a queue works unless it is off limited length and nodes are doing something useful and measurable in order to remain in the queue. Even then, you get the issue of the queue itself being spammed with join-the-queue requests, just like the network so I’m not seeing how to solve this!
Killed both the nodes I had running to exercise churn - so ~120Mb and ~70Mb of chunks just went phut. Recover from that, pal…
Now trying to connect again with @happybeing 's bash loop on the big box
I have your script running with sleep 2
Tell me if this is OK/Not OK
Away out for an hour or so on a WifelyCommand to purchase black crepe ribbons for the Great Mourning.
Back soon
PS Todays sound track is Sydney Devine - Crying Time - YouTube on repeat.
A task which is randomly hard would be good. It would shuffle then pack of joiners, not just based on capacity, but also based on luck. Perhaps completing it would align with network requirements or not. Just need to stop folks with lots of hardware and nodes from loading the pack.
Edit: I say just… much more to consider, but you get the idea! ![]()
Ok, I’ve got my shiny new battery installed so it’s time to set up a nice in the cloud and dust off my Odroids and Raspberry Pi!
Anyone fancy taking four 28Kg batteries to the tip for me? BTW, those lead filled Trojans have been replaced by a single 14Kg Lithium which will charge in about half the time (cost almost identical).
A valid use case indeed. The PR looked good and is now merged too
Thanks @tfa ![]()
I don’t think that’s enough. What we need to defeat is the ability to stack the odds in your favour by applying to join many more times than someone else, and from many different machines (eg in the cloud). I think this is a hard one to solve. In fact it isn’t soluble, but we need to make doing so as costly as possible compared to someone with a single low powered device. I confess I’m stumped.
… If it’s not to be a free for all, then it has to be fair in some other way.
If a body of nodes are required to boot the final network, the sense of where those are could be based on a previous testnet?.. only the elders from that testnet get preferred option to be the strong setup for the network and before others at random?
The other idea that makes no sense perhaps is to disadvantage new nodes, hobble the advantage, until the network has many nodes and can free up activity to all. So, make it treacle like at first, redundant work on the junior nodes to keep them busy… and that way the network requires more nodes for the same amount of work… and relaxes that over time. It would be expensive in the work nodes are doing but if it’s short term perhaps not controversial.
