Re: MockRoutingPack.
Once again, thanks to you and other community members who put this together. I had some issues getting going, but have settled on a Windows setup.
On Windows, the Win SafeBrowser folder didn’t seem to contain an executable anywhere, so I got a different Win download (0.4.2) and that seems to work fine.
On Mac, I couldn’t get the Demo App to run, Mac message says may not be compatible with my current version of MacOS. I included the dump below fyi, seems to be a missing or mis-placed lib, but I’m short of time, so took the easy way and used a Win vm.
Thanks again, all good to go for our meetup Thursday.
Process: SAFE Demo App [1109]
Path: /Users/USER/Documents/*/SAFE Demo App.app/Contents/MacOS/SAFE Demo App
Identifier: net.maidsafe.demoapp
Version: 0.6.2 (0.6.2)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: SAFE Demo App [1109]
User ID: 501
Date/Time: 2017-05-16 11:04:29.560 +1000
OS Version: Mac OS X 10.12.4 (16E195)
Report Version: 12
Time Awake Since Boot: 6900 seconds
Time Since Wake: 970 seconds
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: DYLD, [0x1] Library missing
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/Electron Framework.framework/Electron Framework
Referenced from: /Users/USER/Documents/*/SAFE Demo App.app/Contents/MacOS/SAFE Demo App
Reason: image not found
Binary Images:
0x1028ce000 - 0x1028cefff +net.maidsafe.demoapp (0.6.2 - 0.6.2) <840167AE-5E41-3AF5-8425-4861511E4BFB> /Users/USER/Documents/*/SAFE Demo App.app/Contents/MacOS/SAFE Demo App
0x10d83e000 - 0x10d87bdc7 dyld (433.5) <8239D0D7-66F6-3C44-A77F-586F74525DA3> /usr/lib/dyld
Model: MacBookPro11,1, BootROM MBP111.0138.B25, 2 processors, Intel Core i7, 2.8 GHz, 16 GB, SMC 2.16f68
Graphics: Intel Iris, Intel Iris, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453120
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x802C, 0x31364B544631473634485A2D314736453120
Bluetooth: Version 5.0.4f18, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi 2, AirPort, en0
Serial ATA Device: APPLE SSD SM0512F, 500.28 GB
USB Device: USB 3.0 Bus
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 17.2
