You are right!
I seem to be too, but I still need to redact my statement:
You are right!
It isnāt relevant where the encryption happens.
@dirvine, as the node addresses are random, your initial claim about geographical distribution is misleading. As far as I can see, geographical distribution is not relevant to what is being discussed here. The same maths applies to an event that wipes nodes in a geographically-specific way (like a meteor) as to an event that wipes nodes in a geographically-neutral way (like malware), as 5% of all nodes is 5% of all nodes regardless of where they are hosted.
@toivo, thanks for paging me, glad you used the calculator! You seem to be understanding it correctly. It is indeed specifically for events where all chunks on given nodes are simultaneously destroyed (like for meteors and coordinated malware), rather than events that cause nodes to temporarily shut down without wiping data.
My hope was to limit its impact of inevitable data loss. Iām still convinced that self-encryption over whole files is a bad idea.
If we keep the model of a entire file depending on every single one of its chunks, then weāll need a certain number of copies for each chunk to keep everyone happy. The exact number isnāt relevant to this argument. If we decreased that number by 1, and switched to a format that allowed partial file reconstruction, then that would be a much better outcome as far as I can see. Fewer files would be fully-reconstructable, but overall chunk loss would be significantly lower, and storage would be cheaper.
This also includes such things as (in no particular order)
Now nodes encrypt the chunks when stored to disk and decrypt them when retrieving. This is to prevent any other app on the computer reading the chunks in case there are chunks that did not get self encrypted.
This temp key at this time is only kept in memory and lost as soon as the node stops, thus all the chunks on disk are useless.
This makes the simultaneous drop out even more a danger and why I believe that the temp key must be able to be stored on disk in a safe manner that is not immediately readable. See my later replies to David
I am not sure what you mean here. If nodes were distributed locally, then 5% could take out every copy of every chunk in that locality.
I think perhaps the point is this.
Nodes distributed globally and randomly aids in the safety of replica copies from local network disturbances. This is due to the fact the other replica copies are not in that locality and work away fine creating new replicas when they see the local disturbance. They will see the disturbance as they are logically close, but not be negativly affected as they are geographically apart.
The issue wasnāt to make nodes locally in a geo location but there is no mechanism (rightly so) to make sure they are NOT geo-local for close nodes.
But the issue is that while its a tiny 0.000076 chance of 5 node being in a 15% section of the network (whatever grouping you define) the problem blows out once the file is large. For 3 chunk files there is a 1 in 13,000 chance that it will be affected on a 15% network loss. But for a 13,000 chunk file it is considered a statistically certainity that the file will have one chunk lost.
While this is smaller for say a 5% of the network being lost, its made worse because of the temp key in memory since even a sub second power loss losses all those chunks. How much worse is small but still significant since a large area dropout (eg a city wide power glitch) will not restart with their chunks intact.
I implore you to implement the safe storage of the temp key & any required info so that the node can restart where it left off. This also makes archive nodes more easily restartable. Maybe using the weak encryption of the temp key and brute forcing it on restart. That would mean the chance of losing a large file is extremely small requiring something like China shutting off its internet for a long time.
A lot of those events arenāt truly simultaneous. The bedtime one for instance would just mean a node goes offline and then copies are made to compensate for that. And a lot of those events donāt include permanently wiping the chunks, so thatās not true data loss.
The temp key thing only seems relevant for very brief operations where there is data in RAM. Those operations could just be restarted if they fail, unless Iām missing something here.
This is where randomness solves that issue for us. Trying to control that leads to places that dragons live ![]()
I donāt feel we have a good solition here. The ying yang is this
no encryption
Hackers try and store bad data on nodes to poison the network
in ram key
On reboot you lose the data you held.
I am still not getting this, but if itās a key on disk that is guessable then itās the same problem as no encryption as folk will provide apps to read the data and we are back at square 1 again.
As I say I am not 100% on any track just yet, but itās not my decision either. Itās worth chatting for sure. I was looking at encrypted volumes and such like, all messy and crappy. I have not found a simple solution here.
Another thing I was pondering was chunks that are so small you could not really hide any bad images and certainly not video in them. Then perhaps we can use entropy checks for detecting text, but only plain text and many text formats have a lot of entropy, but then you can check for file header information, but then again random data will sometimes have valid file header looking info too.
So a few things to think of.
BTW I doubt archive nodes would delete all data on reboot.
Its statistically significant though. I was saying the chance of having larger %age of nodes simultaneous is higher.
It doesnāt require an exact simultaneous shutdown to be an effective simultaneous shutdown. Replication of a nodeās chunks on shutdown of the node takes time. Maybe 10 to 20 minutes and if a chunk is only within that group then there is a fair chance of loss. Over a year this could represent a number of lost files.
But if the node was able to restart and either continue on or replicate out its chunks then wide its storage and restart with new ID then the chunks have a excellent chance of never being lost.
No that isnāt the purpose of the temp key. It makes sure the data on disk is unreadable, so on restart the chunks it stored are permanently lost
If you have random distribution of chunks, then there is a chance for any given chunk that all of the copies will happen to be held in, say, London. If London is destroyed, the chunk is gone. The alternative of geographically-aware distribution would mean that chunks are never stored in the same place, and London being destroyed wouldnāt be a problem for the chunks.
Nodes can restart and resurrect any chunks they have (to the best of my knowledge), which is why Iām not concerned about a lot of your scenarios. The big ones to me are large-scale physical devastations (meteors, nuclear strikes) and coordinated malware attacks.
Ah okay. I havenāt come across this before. This sounds crazy so Iām hoping itās not the case.
So true
Not really. The safe storage of the key means that the chance of another app reading the chunks is still reduced to almost zero. Very much a positive. Youāre 99% the protect of only temp key only in RAM.
But for that 1% where a hacker tries to get it then Nope almost the same as key only in RAM.
So in effect the only thing the temp key safely store is the tiny chance another app knows how to get it. But if you go hacker route then they can get the temp key or bypass it anyhow.
But if they use the temp key, for the same protection reason the other node do then yes they would. To leave archive nodes without encryption is to not only make them a target but a good target for anyone wanting to grab large number of chunks that were not encrypted. (eg court orders)
This is why I am pushing for that temp key to be safely stored on disk as well to allow the node to restart and either continue or distribute those chunks before starting as a new node.
If the key is on disk then the chunks can be considered not encrypted, surely?
In that case itās all bets off, they can do anything.
To be clear, what I means here is.
As I understand it, nodes do not encrypt the chunks. Chunks are encrypted before they reach the node. @dirvine is that correct?
edit: The answer was, in most cases, no this is not correct.
They are via the client API, but there is a low level API on the network that allows you to store any chunk. So as long as the content hashes to the name (key) then itās valid. There is no simple way to avoid that.
Is that a yes?
Currently we have the ability for nodes to create a temp encryption key in RAM and encrypt each chunks stored to disk. This is to prevent any app reading the on disk data.
Default and until recently this did not happen.
However any client app using the client API has the data encrypted before it leaves the client.
You can bypass the client API and this is where the issue is.
For most (over 99%) of apps and situations then yes it can be considered encrypted.
Damn you just explained the same as me. In this case then it matters not that the key even exists.
The temp key encryption only protects from dumb/lazy bad people and good people. Those type of bad people represent over 99% of bad people who are just trying to read data off a disk and see what they can.
The bad people who could get at the key safely stored on disk can also just change the node software that is run to a modded one without the temp key at all.
Basically storing the temp key safely on disk does not practically change the security of those chunks. Anyone wanting the chunks will have a way to do it without worrying about the temp key on disk. Grab the in memory copy or mod the node app on the PC to not use it.
By safely storing the temp key using the suggestion made by another poster was similar to what some malware did and is not readable by virus checkers either.
Basically the temp key implementation was for an edge case where the data on disk was easily readable by other APPs if the client did not encrypt the chunk. Or for attackers. While very important for accidental or curious to bad people, it was still an edge case to close that āloopholeā. Hackers or knowledagable bad people it is ineffectual since the key can be read from memory or bypassed.
