Building on Fedora x86_64 - current errors
@Ross,
That is much nicer! - it looks like the results were automatically uploaded so I guess you have access to them but this is the end of the output:
Performing coverage
Cannot find any coverage files. Ignoring Coverage request.
Submit files (using http)
Using HTTP submit method
Drop site:http://dash.maidsafe.net/submit.php?project=MaidSafe
Uploaded: /home/phil/src/c++/maidsafe/build_maidsafe/Testing/20150125-0253/Build.xml
Uploaded: /home/phil/src/c++/maidsafe/build_maidsafe/Testing/20150125-0253/Configure.xml
Uploaded: /home/phil/src/c++/maidsafe/build_maidsafe/Testing/20150125-0253/Test.xml
Submission successful
Errors while running CTest
CMakeFiles/Experimental.dir/build.make:49: recipe for target ‘CMakeFiles/Experimental’ failed
make[3]: *** [CMakeFiles/Experimental] Error 8
CMakeFiles/Makefile2:370: recipe for target ‘CMakeFiles/Experimental.dir/all’ failed
make[2]: *** [CMakeFiles/Experimental.dir/all] Error 2
CMakeFiles/Makefile2:378: recipe for target ‘CMakeFiles/Experimental.dir/rule’ failed
make[1]: *** [CMakeFiles/Experimental.dir/rule] Error 2
Makefile:291: recipe for target ‘Experimental’ failed
make: *** [Experimental] Error 2
Thanks,
Phil.
@Ross,
I have done a second build with a little improvement in results (94% tests passed, 40 tests failed out of 695 vs the previous result of 94% tests passed, 42 tests failed out of 693) and I can now find the uploaded results here:
http://dash.maidsafe.net/index.php?project=MaidSafe&display=project
under “Experimental” so I am making slow progress . .
I am only a novice C++ programmer but is there some sort of debugging I can do now?
Thanks,
Phil.
Hi @philip_rhoades nice work
If you have spare hardware you could run Nightly CI jobs for us (Debug and Release)
You will find these in the build folder for example:
ctest -S CI_Nightly_Release.cmake
and of course come testnet 3 we will be looking for lots of community help :smiley:
@Ross,
I have been busy with other stuff for a while but have I have done the odd build every now and again to see how things were going - I just did another one which got all the way through but ended with:
Uploaded: /home/phil/src/c++/build_maidsafe/Testing/20150313-0155/Build.xml
Uploaded: /home/phil/src/c++/build_maidsafe/Testing/20150313-0155/Configure.xml
Uploaded: /home/phil/src/c++/build_maidsafe/Testing/20150313-0155/Test.xml
To get it to work I had to restore a line in my README recipe file to fix gcc problems again:
git clone git@github.com:maidsafe/MaidSafe
git -C MaidSafe submodule update --init
vim ./MaidSafe/cmake_modules/add_boost.cmake
Change:
find_library(Icui18nLib libicui18n.a)
find_library(IcuucLib libicuuc.a)
find_library(IcudataLib libicudata.a)
to:
.so
cmake -HMaidSafe -Bbuild_maidsafe -DCMAKE_BUILD_TYPE=Debug
cmake.sh # Removes “toolset=gcc-4.9;” from cmake files
cd build_maidsafe
make
make Experimental
but the main thing that I have been meaning to ask is: How do I do an incremental build? - whenever I have tried to do a “git pull” (instead of a “git clone . .”) in an existing MaidSafe dir and then proceed as normal through the rest of my README recipe, I always have a problem - so I have always had to start from a clean “git clone” again. Is there some trick I am missing?
Thanks,
Phil.
The last couple of attempts building from scratch - using:
Fails with:
Configuring MaidSafe Launcher project on ‘HEAD’ at commit ‘02288b2’
– GTests included: All. 14 Google test(s) enabled.
– Didn’t find all required modules of Qt5. Not building Launcher UI.
– To see values of cached CMake variables, run ‘cmake . -N -LH’
– Cloning git@github.com:maidsafe/ContinuousIntegration
– Installers unavailable with Debug configuration
– Configuring done
CMake Error at cmake_modules/add_protoc_command.cmake:108 (add_custom_command):
Error evaluating generator expression:
$<TARGET_FILE:protoc>
No target “protoc”
Call Stack (most recent call first):
cmake_modules/utils.cmake:131 (ms_add_protoc_command)
src/encrypt/CMakeLists.txt:42 (ms_glob_dir)
P.
I haven’t tried this on fedora though if you just cloned the repositories; be sure that each one is on the correct head;
git checkout next
for each folder inside ~/MaidSafe/src/(repository name)
then build again;
@dallyshalla,
Same result but thanks.
Yes. Search the site for old posts about QA/dev.
You can. Create a Github account, fork or download the code and apply the PRs you want to test.
@janitor,
I have been using the command:
make Experimental
(as long as everything else works and I get to that stage) and that sends the test data off automatically.
That seems to help! The build got all the way through with only six errors this time.
Thanks!
People,
I finally got around to building a separate (beefier) workstation from my server and have just now tried the newer Rust-based builds. For building crust on Fedora 22 I get:
Compiling crust v0.2.1 (file:///home/phil/src/rust/maidsafe/crust)
src/beacon.rs:168:14: 168:58 error: no method named set_read_timeout found for type std::net::udp::UdpSocket in the current scope
src/beacon.rs:168 .set_read_timeout(Some(Duration::new(10, 0)));
error: aborting due to previous error
Could not compile crust.
Phil.
Are you using nightly for crust (unfortunately required for now)
@dirvine
I used this script:
I thought that would use nightlies?
Thanks,
Phil.
I do not see any rust version info there.
@dirvine,
Sorry, I thought you were talking about nightlies of crust not Rust! OK, so I got past that problem and after installing libsodium[-devel] RPMs everything built OK with only a couple of lint warnings.
Firstly - I don’t know how much of the C++ code this has replaced but it is SO much faster to get through this process!
Secondly - is there the equivalent of “make Experimental” to test the code?
Thanks!
Phil.
You can now do, in each library directory:
cargo test
Or
cargo build --example [example-name]
Look in the examples sub directory to find out what examples each library had and insert the name to build it. Then run it and hope the help / UI is self explanatory! :slight_smile:
Also
cargo doc
To build the docs (output under ./target)
!00% plus we are much farther forward now. Significant improvements all around especially security. It’s a cool project now with a lot of easy to test conjectures, which makes the whole thing faster and much more efficient.
I would agree. Everything of the update/install to running the tests/codes is lightening fast. I am getting so excited I can barely contain myself.
People,
I have modified this script:
to also build and test the code as well:
I do a “pull” serially but run the builds and tests in parallel on my new machine (putting each dir test in a new xterm) - as of just now, “crust” is the only one with errors and “cargo test” hangs indefinitely . .
Regards,
Phil.
@happybeing,
Are results from different machines still being uploaded somewhere? Is there a command for doing that in this environment?
Thanks,
Phil.
