This file contains both 32-bit and 64-bit binaries. I used the 32-bit library, but in this same file’s libsodium-win64/lib subfolder, it has the libsodium.a there. So copying that over to ./bin/x86_64-pc-windows-gnu should allow you to link it. Let me know if that doesn’t work.
Thanks a ton @eggmunkee
I realized with your message that 7zip was not displaying correctly the content of the archive… with winrar I found the file. Going to chunk my hard drive away to celebrate!
Hello i play with the self_encryptor on 64-bit machine and everything is fine but on
xubuntu 15.04 32-bit machine, i am less lucky
I put CFLAGS=“-mmmx -msse” in my .bashrc but that did not help.
Here’s what i get:
/home/scv/.cargo/registry/src/github.com-121aea75f9ef2ce2/sodiumoxide-0.0.6/src/crypto/verify.rs:63:52: 63:66 error: mismatched types:
expected u32,
found u64
(expected u32,
found u64) [E0308]
/home/scv/.cargo/registry/src/github.com-121aea75f9ef2ce2/sodiumoxide-0.0.6/src/crypto/verify.rs:63 ffi::sodium_memcmp(x.as_ptr(), y.as_ptr(), x.len() as u64) == 0
/home/scv/.cargo/registry/src/github.com-121aea75f9ef2ce2/sodiumoxide-0.0.6/src/crypto/verify.rs:63:52: 63:66 help: run rustc --explain E0308 to see a detailed explanation
error: aborting due to previous error
Compiling memory_map v0.0.2
Compiling flate2 v0.2.7
Compiling docopt v0.6.70
Build failed, waiting for other jobs to finish…
Could not compile sodiumoxide.
To learn more, run the command again with --verbose.
This is a bug in the sodiumoxide crate, it has been patched but the author has not updated crates.io just yet. We have a fork if it goes to long without an update. So 32 bit machines have this issue just now.
