OK blood pressure down a wee bit
We have a communication problem, not a fundamental problem if this is in fact the case
Thank you @bochaco ![]()
The 0.000000001 is the cost of creating a balance ![]()
So from 10k coins, you are sending 500 to the new balance. Thereās a cost associated with actually creating an empty balance (keypair) on the network. Itās a piece of data that needs to be stored on the network, hence the cost. Hope that makes sense.
A little bit of background on this, we initially didnāt have it. But later we identified the possibility of an attack. Consider this scenario,
Lionel has a balance with 10k coins. If creating a balance is free then Lionel can create 10k balances with 1 coin each. And at the end transfer all the coins back to his initial key. Now he can repeat this process n number of times, and flood the network with empty balances.
We need to prevent this, hence the cost ![]()
EDIT: Didnāt see Gabrielās reply before I sent the above
Hope the explanation helps anyways ![]()
new issue created at https://github.com/maidsafe/safe-api/issues/497
Thank you @lionel.faber, that all makes perfect sense. we simply need to tell folks about this up front.
Us testing geeks can live with this cos now we know but its another job for @JimCollinson and the GUI design to make sure this is communicated appropriately
Can you confirm fixed point integer is being used and the balance is stored as an integer from 0 to 2^32 * 10^9
Many in the community identified this attack long ago even before division was solved
Thisāll kind be inherant to the onboarding process:
The cost of creating an account will be greater than just making a balance, but still tiny.
An account āpacketā will be circa 1MB, but thatāll be all you need to create your account, set up a SafeID, profile etc, with enough left over for some basic transactions.
Youāll either be getting this via an invite from a friend, earning it yourself with a vault, or via a purchase from an exchange (down the line a little way).
Itās all built in to the value of in invite, and redeeming that invite pays the network for that stored value. So Iām not sure youāll need a particular warning about that cost⦠if Iām following you correctly.
Of course. I meant that we identified it as a bug in our code ![]()
Itās actually a u64 . See the declaration here.
Maybe Im being pedantic here but it would be good to keep this issue front and centre in the minds of app-developers.
So I have great faith in you sorting this out for Joe User, Iām more concerned right now about app-developers - especially those who are new to the project - being caught out with this.
Thanks to @bochaco and @lionel.faber for quickly putting this to rest
So if there is a nano cost for creating an account -which is fine
- then those costs will presumably be being collected and stored in a network wallet somewhere - so we could query that account and infer how many new safe-keys, wallets etc have been created in this new public shared section - yes?
EDIT: Anyhow - back to trying to break this ![]()
Well actually no.
The cost just ādisappearā for now. They will be paid to the network later on.
There is a list of safe-keys created maintained in the section, yes. But Clients cannot query this and get the list of keys available.
@lionel.faber OK makes sense but does this mean ( for now) the devs cannot find out directly how much usage this new shared section is getting?
And thus you need to rely on feedback from us or just infer it from network traffic to the droplets?
Iām a bit vague on this - sorry
Actually, good point. One way could be to look at the logs, or access the balances-db on the droplet directly. ![]()
Tried the above again and it seems the account was created but Iām still getting the timeout while bootstrapping. Any ideas?
Are you absolutely certain you are connecting to the new shared section?
Sorry if its a dumb basic question but sometimes they need to be askedā¦
Does safe networks return something like this?
BTW it would be just peachy if safe auth status could be tweaked to say just which network it was logged intoā¦
This is a bit vague⦠
No dumb questions where Iām concerned. It does indeed show the shared section:
safe networks
| Networks | |
| Network name | Connection info location |
| shared-section | https://safe-vault-config.s3.eu-west-2.amazonaws.com/shared-section/vault_connection_info.config |
Sorry - I had to checkā¦
and you definitely ran safe networks switch shared-section
and then safe auth restart ?
Could be something- could be nothingā¦
So the first thing I did on learning the joyous news that a shared section existed was
Fast forward a few hours and I return to thisā¦
something wrong in the img sub-dirā¦
so as you can see I double-checked on the original and it is as expected, two images.
So try the upload again and this time it all looks perfectly fineā¦
safe tree output matches local tree output as expected.
Do we need to be careful with filenames with hyphens? Surely notā¦
And for the insatiably curious amongst youā¦
Arran from Troon at sunset
RabC paddling with his picnic
So, very good first impression of this.. it works
Itās getting harder to find big problems and normally try to avoid minor.
Still.. first impressions
Users will see certain commands that rightly follow Linux naming convention and expect that behaviour would follow through to where those commands action.
So,
safe ls
safe rm
should work?
safe files ls
needs recursive option as -R
Thereās inconsistency with near top level options, having help and others requiring double dash --help
So, safe files rm help doesnāt work, having been encouraged by previous habit.
I wonder the big missing option then is
safe man
as reference manuals.
By all means keep help but either help is symbolic for man or other way round.
So,
safe man rm == safe help rm
As a list of options, we could see safe help subcommands as they are and then below, the set that are children but usefully there at top level as direct actionable.
Again, this all following the form of Linux CLI, that is useful naming convention for this.
I have yet not to get stuck on
...awaiting link URL from stdin
So,
$safe nrs create thistest gives that and I couldnāt create a public name.
What is ānrsā?.. I can see itās public names but that acronym isnāt meaningful.
Should it become just safe names?
What I havenāt tried is to test the notion that you pay for put. That is, what happens when the user disconnects part way through upload.. do they still pay?.. are you paying to try to put, or only when successful?
You are missing the --link flag: https://github.com/maidsafe/safe-api/blob/master/safe-cli/README.md#nrs-create
You can also just paste the link URL when you get that message you are getting.
but it doesnāt seem that allows option for input.
I wonder it could dump into a query that is expecting PublicName and then the FilesContainer address as input
(two fields expected as PublicName and FilesContainer)
PublicName: inputherethistest
FilesContainer: inputheretoomanycharacters
Also, I wonder if it might be possible to consider the context within which the user is working⦠even if that needs a confirmation of intention on the back of assumption about what is wanted⦠enhancement for the future perhaps.
