Man this is a long convo, there is defo a miscommunication here.
Can I start this reply with - AD is what we currently have sans multisig. We are not losing here but gaining. The only thing we remove is the zero out of a value from a key value pair. It allows AD to be more consice and exact in it’s specification. It does not prohibit more data types down the line in any way.
Also AD and ID do not means apps cannot edit data, they can, they can remove things from presentation (“delete”) so apps will just see a network they can do all these things on from a user perspective. I think folk think we are removing ability for users to edit data here and we are certainly not.
I don’t think it is, but it is what we have now in a pseudo way. True Appendable data as we will proved makes this more elegant.
Data is immutable, due to immutable data type. Where to find that is the appendable data type. If we end up in the future with actual Mutable Data (edit/delete) then that is all OK, but it has to be in a eay that other things like perpetual data cannot be damaged.
2 Type Immutable Data (hash of content == name) this is self-checking data. Then appendable data, eay to think of this as pointers to immutable data. This allows data representation to change. i.e. now this file has this content (i.e. it points to new chunks). All the history and data is still on line though.
An immutable data chunk can also be a list to pointers, so it allows a mix of data types for instance to make up a video etc. Thik like this video == 1billion chunks so AD has pointers to 1000 but the last pointer is an ID chunk that has more pointers etc. This is how you can have a mix of data types to represent a file.
I am aware the guys are finaliseing RFC here so don’t want to step on toes, but related to last point. AD is a list of pointers (those can be identities etc basically xor addresses) that is finite. The last item of this list will be to further history contained in an ID chunk.
AD is as MD is now, when you register a change it appends a new list item (right now it is a key value pair, where the value nullifies). So change there is not a key value, but a list, so smaller, more efficient and not scrubbing history. The existing thing scrubs history but leaves the data in place (zeroed out).
If you wish to put temp stuff on a perpetual data network then you can, but there is a network cost to doing so and the network will need to take a payment. So now all we do is say it will be permenent and this is the cost. If it were not permenent then you need to sign it to prove you can delete it, then we need to know you have not shared it then perhaps it can be deleted BUT you just exposed the inner workingsof your “stuff” to the world on a network that folk can ask for your stuff, did you really encrypt all that stuff, if you did it must have been in RAM etc. or stored on disk locally (please not plaintext). All this is much more additional work/design to allow folk to use the network as a temporary storage solution? It might be easier to ask the client managers you are connected to for some play areas etc. It is a new feature though that needs really thouroughly thought out.
I claim this is all not thought out as much as it should be and is additional work/design/code and will delay launch. If the whole community want us to do that then it can be done, but it is absolutely not required at all. Local apps can use local temp storage that is secured and wiped, that is faster and more efficient. Where they cannot then they log into a bigger machine that can, at least right now.
I agree, so say you render a 100Gb video, that rendered can create many terrabytes of temp data, it does so locally and scrubs it, but itf you wanted the network to hold it you have huge bandwidth costs etc. (SAFE and network like it are bandwidth bound).
It is doing as data is doing now, but more efficiently and not scrubbing entries.
By the app as the last item is that AD completed. So the app has to make the last item a link to another data element or the AD is closed (just as now).
Just as now really.
Of course, but this would be to do more than we curently do in Alpha2 and will need consensus on edit/delete as you can have collisions there even from a signe user loggend into 2 seperate devices and so on. So there has to be consensus on those changes, therefor it will be slower. If data is CRDT like then you can do things very fast comparted to consensus requiring data types. This is due to the latter requiring mechanism to hanndle conflicts. Even with append only there are opportunities for conflicts, but much simpler to solve.
I think the Appendable Data RFC needs to happen sooner than later for the sake of the community to show this is explanding what we have in alpha 2, so all alpha2 apps can work but more will be possible with true AD and multisig.
I feel there is a knee jerk here that folk think, we are losing something ehre, we need ot quickly design alternatives, but we are not losing stuff here, we are getting more.
Then a debate on temp files, rewriting history, deleting certain data etc. can take place without distraction of quickly repairing something that is not broken ![]()
EDIT - I burned my porridge answering that, the price we pay
