AntTP - Serving Autonomi data over HTTP
There is a new release out which should fix the above automatically. Change log:
  • Integrate proto compiler into native Rust build (#92) by @traktion in #94
    • Adds rmcp feature “transport-streamable-http-server-session” by @traktion in #97
  • Fix public archive download issues and improve CachingClient tests #93 by @traktion in #99
  • Immediately execute get pointer commands instead of queuing #98 by @traktion in #100
  • feat: add PNR sub-name resolution (#101) by @traktion in #102
It also bumps to the latest Autonomi 0.10.0 libs.
There is also a cool new PNR feature, where you can now create sub-names and resolve to them. It’s still experimental, but combined with the key/value support, pointer caching and chunk caching, it can make for very rapid key/value retrieval (it’s like a hashmap lookup using the sub-name).
As a quick example, here as a key/value I created earlier:
http://localhost:18888/message1.chatskip (gateway) or http://message1.chatskip (proxy)
http://localhost:18888/message2.chatskip (gateway) or http://message2.chatskip (proxy)
Or just some regular PNRs that I created to replace the (static) bookmarks of AntTP old:
http://localhost:18888/gimim/blog/blog.traktion (gateway) or http://imim/blog/blog.traktion (proxy)
http://localhost:18888/gimim/blog/maidsafe/autonomi (gateway) or http://imim/blog/maidsafe/autonomi (proxy)
http://localhost:18888/gindex (gateway) or http://index
Or maybe some directory listings, to show off the new look:
http://localhost:18888/blog.traktion (gateway) http://blog.traktion (proxy)
EDIT: @Southside is working on getting Ant’s Nest updated, so I’ll update the links above with those too, once we are live.
Github: Release v0.24.4 · traktion/AntTP · GitHub
Dockerhub: traktion/anttp - Docker Image
Cargo: cargo install anttp
Edit: You may still need to cargo install anttp --locked if it fails to build.
@Southside is waiting patiently in line for his pizzas - Oro is busy busy busy but the wifi is excellent - so are the pizzas usually.
So youse will need to be patient too
New release of AntTP, to partner nicely with the new AntFTP.
Focuses on bug fixes and public archive improvements.
Changes since last release
  • Merge pull request #132 from traktion/feature/issue-131-improve-ci-cd (a97a9c2)
  • Improve CI/CD workflow based on AntFTP; increment version; add spec file (9763e38)
  • Merge pull request #130 from traktion/feature/129-sync-public-archive (b45f517)
    • Renamed function (as not recursive) (46c4a44)
  • feat(public-archive): implement push flow by rebuilding archive from cached file content and persisting to target; add unit test; bump version to 0.24.18 (8343d8e)
    • Moved write REST endpoints into write permissioned section in lib.rs (475697d)
  • docs(REST): document new POST /anttp-0/public_archive/{address} push endpoint; test(postman): add Push Public Archive request to collection (0b1ac4d)
  • feat(public-archive): add push endpoint and gRPC/MCP support for syncing cached archives to target store type; add proto PushPublicArchive; wire REST route; bump version to 0.24.17; add spec for #129 (e50c9e9)
  • Merge pull request #128 from traktion/feature/127-support-names-for-pointers (7fa36e1)
  • Refactor: extract address resolution logic into a separate function in pointer_service.rs (03dd19e)
  • Support names as well as addresses when getting or updating pointers (#127) (37c847b)
  • Merge pull request #126 from traktion/feature/125-fix-bugs-around-paths-and-error-handling (ec3e179)
    • Bug fixes for bad paths in HTML listing, bad error handling when errors, and additional debug (8b34ac7)
  • Merge pull request #124 from traktion/feature/123-update-archive-handlers (6c23ace)
  • Update public_archive and tarchive gRPC handlers to support path and store_type, aligning with REST API. Updated protos and incremented version to 0.24.15 (3aecb17)
    • Improvements to how gRPC server handles error and shutdown (4f74b82)
    • Trim leading slashes from archive search strings to avoid mismatches (0eb409f)
  • Merge pull request #122 from traktion/feature/121-path-detail-items (338c857)
  • feat: #121 Update list_files_json and list_dir path/display semantics (64072d4)
  • feat: #121 Return PathDetail items for Public Archive REST; update gRPC proto to include Item and map PathDetail; bump version; add spec file (934986b)
  • Merge pull request #120 from traktion/feature/issue-119 (f4477a9)
  • archive: trim leading slash in list_dir search_key to avoid bad filters; add unit test (1eea3bb)
  • Finalize Tarchive refactor: remove TarchiveForm and align with PublicArchive endpoints (6574f10)
  • Remove target_path from PublicArchiveForm; introduce TarchiveForm for tarchive flow; update gRPC and MCP tools; adjust controllers and services; tests green (7533d5d)
  • Update Postman collection for public archive endpoints (7e98a9d)
  • Implement issue #119: Update POST and PUT public archive endpoint to use URL path as target path (c565ba8)
    • Updated bookmarks default (to empty) and minor house keeping. (c208c40)
  • Merge pull request #118 from traktion/feature/116-public-archive-grpc (f2c00c4)
  • feat(grpc): add get and list files support for public archive to gRPC (7e593a6)
  • Merge pull request #117 from traktion/feature/110-delete-file-support-public-archives (1d1ba6f)
  • test: update postman collection with DELETE public archive path test (0a8e57b)
  • feat: add delete file support to public archives REST API (#110) (a8c307e)
    • Revert stale test runs (19382af)
  • Merge pull request #115 from traktion/feature/issue-111-public-archive-rest-api (9a51662)
  • Fix test_get_public_archive_with_path in public_archive_service.rs (db69fd3)
    • Revert accidental debug enable (0d6ad5f)
  • Update postman collection and fix public archive raw retrieval bug (b8920ea)
  • Add get and list files support to public archive REST API (Issue #111) (e00519c)
  • Merge pull request #114 from traktion/feature/72-fileservice-tests (405afe0)
    • Removed stale/commented code (9f502a5)
    • Fixed some mock tests and removed stale resolver_service.rs (pre-mock) tests (can be re-created in follow on issue). (56ae89c)
  • feat: add unit tests for FileService and improve PublicArchiveService #72 (5ef59fd)
    • Refactors to extract streaming client to avoid circular dependencies and mocking difficulties - Removed many test compile warnings (0f05061)
  • docs: add permanent copy of issue 72 requirements (2f93aa8)
    • Adds mocking for caching clients. - WIP: breaks tests (d83c694)
  • Merge pull request #113 from traktion/feature/issue-71 (f422923)
  • Fix file_service.rs tests by bypassing mock constructor in test helper (911b12f)
  • Add unit tests for PublicArchiveService and implement get_public_archive #71 (92a03cd)
  • Merge pull request #109 from traktion/issue-108-target-path (4fd90eb)
  • Refactor TarchiveService to extract build_tar_from_form common logic (3156da4)
  • Fix target_path processing in TarchiveService (37d8493)
  • Implement target-path support for Tarchives and update Postman collection (bb63554)
  • Fix Swagger UI rendering for public archive form and update documentation (9993022)
  • Add target-path support for public archives (issue #108) (7308d9a)
  • Merge pull request #107 from traktion/feature/106-head-support (109ec14)
    • Added no_chunking to ensure content-length is populated. - Added Last-Modified header when known. (31b38e5)
  • Add HEAD query support to return content-length and no body (1e5223f)
  • Merge pull request #105 from traktion/feature/104-prevent-range-queries-on-tarchives-overrunning-file-length (2e77f20)
    • Added spec file (b179682)
    • Version bump (bc1510d)
    • Fixes issue where range-to returns data beyond the file length. Primarily, this fixes tarchive retrievals, due to them being embedded in a tar. (8eab6b6)
What’s Changed
Full Changelog: Comparing v0.24.4...rolling-a97a9c249efc07ca4250d426e3e928334fe6573c · traktion/AntTP · GitHub
Github: Release v0.24.19 · traktion/AntTP · GitHub
New AntTP release with a focus on fixing tarchive bugs and adding tarchive API features.
There is a new general concept of ‘archives’, which include both public archives and tarchives. This gives both archive types the same interface, allowing them to be interchangeable.
  • Bumped version for release (971da5c)
  • Bumped version for release (5800967)
  • Implement push_archive for tarchive (#148) (9e88361)
  • Feature: Unified Archive Interface (#144) (#146) (b5cabfa)
  • Add get, list, update and truncate tarchive features to MCP tool and gRPC handler (#145) (2f0b187)
  • Add get and list files support to tarchive REST API (#143) (f4d4f49)
  • Add delete support for tarchives (issue #138) (#141) (e403a91)
  • feat: Add public data and tarchive push/sync capability (#137) (#139) (8053a13)
  • Merge pull request #136 from traktion/feature/issue-135 (de70356)
  • Move tests to the bottom of tarchive_service.rs (1671ff7)
  • Add workaround for tar crate file append bug (f42ccea)
  • Merge pull request #134 from traktion/133-fix-issue-with-tarchive-not-being-detected (4a61647)
  • Fixes issue with tarchives not being detected, due to an optimisation on reading public archives (public_archive_caching_client) in a prior change (851c2ce)
  • Minor keywords addition to cargo.toml (a0cb1b7)
    • Version bump (3fb6490)
What’s Changed
Full Changelog: Comparing rolling-a97a9c249efc07ca4250d426e3e928334fe6573c...rolling-971da5cd63182556ee6cef59720bc4b70189bb40 · traktion/AntTP · GitHub
Github: Release v0.25.0 · traktion/AntTP · GitHub
